slow into drive from reverse
Morning all, lately i've noticed one of my sevice trucks an 04 f-350 w/6.0, 5-spd auto is taking 4-5 seconds to engage drive from reverse when I back out of the shop. I dont think its the cold, seems I remember it a few times when it was warmer. It stays inside at night shops about 45-50 degrees. Is this a common problem with the 5-spd or maybe electrical quirk? Oh I only have about 47K miles on it. If it persists I'll be taking it to the dealership for service. Thanks for any and all help.
I had the same problem and replaced a solenoid and cured it right up!
Now I cant recall 100% but it was something like the main pressure solenoid...cant recall the exact name. If you can get ahold of a tech familiar with the trans they should know it just from the description. My solenoid was around 80$ and was pretty easy to replace myself with the truck on a lift. Just plan on refilling with fluid and maybe changing the filters while in there. |
bump for the answer to this, i am having the same problem
I had the same issue at about 42k miles...let it go for too long and it only got worse. Ended up being a solenoid issue but at that point for me it was beyond just replacing the solenoid and had to get a new trans. Get it looked at now instead of later...$80 is better than $3000
Oh, and I remember seeing a recall for this at some point but it had an expiration date of sometime in 2006
I had the same problem also....it was the line pressure control solenoid, Brian@BTS gave my tech the part number of the soleniod...about $80 and needs to have the whole solenoid/valve body assembly taken down,afterwards it was great for a while.....not to be the bearer of bad news.....but......I just got done having my trans rebuilt(although now its billet built
