Trans Fluid? - Ford Powerstroke Diesel Forum
Old 11-28-2009, 02:16 PM
Trans Fluid?
Today I was going to get my trans flushed at a near by quick oil change and when they hooked up the machine and I started my truck and the new oil wasnt getting sucked in like it was supposed to. The guy wasnt sure why it wasnt working so in the end I didnt get it flushed. On Monday I plan on taking it to my normal mechanic that does all the work. What would cause this to happen?
Old 11-29-2009, 07:51 AM
I can't answer your question as to 'why' this happened, but I would be leary of any quick lube place doing a fluid change on a TorqShift and would question heavily what fluid they are using.
Aside from the ultra expensive dealer item, we've had great success with the Wynn's Multi in our shop in customers trucks that are moslty contractors units.
Old 11-30-2009, 03:00 PM
only AMSOIL or Motorcraft make the mercon SP
Old 12-09-2009, 09:05 AM
Only Motorcraft makes Mercon SP. Amsoil makes one that they say is equivalent. I'll stick with SP, my dad runs the Amsoil and tows heavy with no issues.
Old 12-09-2009, 01:41 PM
AMSOIL makes a low viscosity transfluid
AMSOIL - Synthetic Fuel Efficient Automatic Transmission Fluid (ATL)
AMSOIL Synthetic Fuel Efficient Automatic Transmission Fluid is recommended for automatic transmissions and other applications requiring DEXRONŽ VI, MERCONŽ LV, SP or Toyota WS.
I run amsoil front to back (axles, engine, trans)
Old 12-09-2009, 01:47 PM
I know they make one for Mercon SP applications, but it doesn't match the specs exactly as it covers multiple fluids.
Old 12-09-2009, 01:54 PM
true, i still run it and havent had any problems
Old 12-27-2009, 10:21 AM
To answer your question: Fords are notorious for having low line pressure. Need to have some idle up the truck while flush machine is running.
Old 12-27-2009, 11:17 AM
If he was connecting to the cooler lines, there is a thermostat and it has to be up to operating temps for them to flow. Take it to the dealer for a flush, or just drain the pan and refill with 7-8 quarts. I do the drain/refill every 15-20k.
