Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 09-25-2009, 05:58 PM
dannyboy950 dannyboy950 is offline
Tranny jumps in/out of gear if you pass 70mph
This is an 05 with a 6.0 eng an 6.0 tranny. You can drive it all day with no problems as long as you don't reach 70 mph. when you pass 70 it quickly jumps in an out of gear, quite a jolt and dangereous as hell.
Any ideas. Scan tool only shows code for a speed sensor malfunction.
Old 09-25-2009, 08:02 PM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
A bad vehicle speed sensor, (VSS) can cause the trans. to do some stupid things. Would probably get it replaced and clear the codes and recheck it.
Old 09-30-2009, 07:26 PM
replaced the speed sensor and that seems to have done the trick.
Old 09-30-2009, 07:48 PM
Tyler Tyler is offline
scuffs *****
Send a message via AIM to Tyler
Glad to hear brother@!
Old 10-05-2009, 04:55 PM
Well that didn't last long. It started doing it again but only after being driven a good while. Ran ISIS and found there was a flash that is related to this problem. Took it to the dealer for them to flash it. Will let yall know if this cures it.
Old 10-16-2009, 05:44 PM
Well the flash didn't handle it. It is back again.
