Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 09-20-2009, 10:19 AM
holbc holbc is offline
Tranny Vibration
I noticed the other day that my tranny seems to vibrate in the lower gears a little bit. I did not do this till I put the SCT tuner on, at least not that I noticed...anyone had this problem before?
Old 10-01-2009, 06:04 PM
STORMTROOPIN STORMTROOPIN is offline
you feelin it through the floorboard, almost like a grinding?? if so thats the same issue im having. It said on my oasis report that it had the planatary gears tsb done before i bought it. idk what is causing this on my id be intrested to see what yours is
Old 10-01-2009, 06:19 PM
6.0DSLPWR 6.0DSLPWR is offline
Ive got a similar problem. I notice it in all gears and it seems the worst between 1500 and 1800 rpm. I mainly feel it in the pedals and I just noticed when sitting at a light idling I can feel it slightly if I put my hand on the center console...if I put the truck in neutral at the light it goes away.
My truck had it when stock...then I put my 4" exhaust on and it got slightly worse...and now after running the sct for approx 8,000 kms it seems to be getting worse again.
Old 10-02-2009, 06:49 AM
Ive been having this issue for about the past 7k miles or so along with a few other issues. cant solve this one yet. i want to change the fluid in the trans and see if that would help.
Old 10-02-2009, 06:59 AM
like I said it didn't do this till I put on the sct...but it only does it in a certain rpm range...if I accelerate it goes away or if I let off...i dunno...I wonder if it has to do with the torque converter.
Old 10-02-2009, 10:13 PM
hmm.. i dont know man. Had an intresting development with mine tonight. Went to put the truck in tow/haul and it wouldnt go. the light on the dash lit up, but you ushually feel it change. I got nothin, then the grinding/vibration came back and was prety bad for about 5 or 6 miles.
Old 10-17-2009, 09:04 AM
onecrazyblackredenck onecrazyblackredenck is offline
are you talking about when you are at a stop and get on it real hard? Sounds like torque converter sutter to me. Mine has been doing it now forever. Pisses me off. Let us know when you find out what it is.
Old 10-21-2009, 07:12 AM
If im idling or getting on it it doesnt do anything. Its only when Im accelerating at a normal rate, usually happens when Im just above 2000 rpms or so. Accelerate harder and it goes away. I dunno
Old 11-18-2009, 12:21 PM
T.R.P. T.R.P. is offline
seems mine started this now that I have the sct. what the hell is it?
Old 11-18-2009, 03:49 PM
Its probably something to do with the torque converter. The factory torque converter is pretty crappy ive heard. Change that out and you should be good so ive been told. Just dont have the money for that right now
