Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 02-16-2007, 04:36 PM
djordan1184 djordan1184 is offline
Angry Stuck Trans
I had a problem with my trans today.Here it is.
Stopped off to get sigs on my way to work.When Igot back in my truck I had to put it in 4wheel cause I was on ice and an incline,got out fine put the truck in newtral (yep can't spell)and took it ou of 4 wheel but it did not disengage so I backed up alittle bit like you had to do with older 4wheels,still no luck.So I proceeded to work in 4wheel.It was buggin the hell uot of me so I stopped off at a parking lot tried to disengage it again first from nuetral and then from park,no luck on either.So then I put it in 4low biiiig mistake now i'm stuck in 4low.Well only about a mile from work so I went but took it easy.when i got to work I put it in park turned the auto nob to 4 high then back to 2wheel and it finally went off.has anyone had this prob. before(there 4wheel sticking.And if not does anyone know what caused this thanks.
