change solenoids 5r110 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-11-2009, 06:31 AM Thread Starter
lifetime member
Exclamation change solenoids 5r110
has anyone changed their solenoids in the tranny? does the solenoid body have to be removed from the tranny, or can the solenoids be swapped out by just removing the c-clip on each solenoid. i was reading a book that says "all can be removed except for one of them" .this would be the line pressure solenoid. i don't know if this info is reliable.
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #2 of 4 Old 01-04-2010, 11:15 AM
bump wondering the same thing
ac540 is offline
post #3 of 4 Old 01-04-2010, 11:18 AM
Snake's Avatar
Quoted: 47 Post(s)
I think Doug at Direct Injection Performance has some type of solenoid replacement. He's the only person I've heard of....
gogodiesel dot com
Snake is offline
post #4 of 4 Old 01-15-2010, 05:01 PM
plowin4u's Avatar
I just did mine, the epc or line pressure control solenoid is the only one that requires solenoid body to be removed, because the large connector is in the way and it needs to slide thru the body so you have enough room to slide that in and out, all others can be serviced without removing valve body, if you have to do the epc one, you have to order the valve body gasket and o-ring for the connector, and only remove the 8mm bolts not the 10mm ones. Make sure you torque valve body in sequence and to correct spec, I think it was 89 in lbs.I definitely recommend changing the inline filter also.
Cliff
2004 F250 6.0 diesel, Foose wheels w/ Bridgestone duelers, 2 1/2 level kit w/ skyjacker shocks, Recon led mirror lights,Recon led third brake light, Recon roof lights, Meyer snow plow, Alpine radio, Kenwood amp, MTX sub.RCD EGR Delete Kit, Magnaflow 4" Dual Exhaust w/5" tips, More to come.
plowin4u is offline
