6.0 problem ?????
ok my dads 05 6.0 has a problem odviously checked codes at work and replaced ficm cam and crank sensor the ficm codes are not coming up again but the cam and crank are truck still wont start only codes coming up are cam crank and egr but the egr wouldnt have an effect on it not starting i also checked fuel filters and checked fuel pressure its all fine where do i go now also its blowing out white and gray smoke when it does turn over for 3 seconds any ideas
with it white smokin and not starting this is what happened to my brother in laws dodge it come to be his injectors, that may not be it but if all else fails check them.
no codes on injectors theres nothing i just dont know what to do with it its a complete guessing game just need to get it running so he can trade it off for a duramax or a dodge
hook it up and buzz test the injectors 2 make sure !!!
The 2 times my truck has been in for warranty work and there was injector issues, there was no codes that lead to injector failure. You have to buzz them and see what ones look like there are failing.
buzz test done this mornin still nothing i have no idea what to do besides pull valve covers and check them all visually and look for other problems possibly do a compression test hell if i know
What is a BUZZ test
when you run a diag on a 7.3 or 6.0 for the injectors it will make a buzz sound there for buzz test
We buzz tested mine using a Snap-On obd 2 commercial shop unit, it gave no codes on the initial scan, and also said the injectors passed the buzz test. #6 injector was bad the whole time, the ford dealer's computer found it on the second try. The snap-on might have after a couple try's but it didn't the first time.
There was a 3 day gap between trying the snap-on first, then taking it to the dealer today, but the symptoms were the exact same the whole time... Just figured I'd put that out there, the buzz test apparently isn't foolproof. |
