Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 05-28-2009, 07:05 AM
smboudreaux smboudreaux is offline
blowin lots of white smoke
heres the story. i had to make a run out of town for work. about a 700 mile round trip run. just into my trip my service engine light came on. i pulled into a truck stop to check things out. i noticed my coolant resevoir was low so i toped it off. later on the light went off. i came home yesterday with no problems, no lights on the dash, the truck performed fine. this morning i went out side and started my truck to let her warm up a bit. after about 10 min i went out to leave for work and noticed was truck was puffing white smoke. i took it down the street and it started blowing large amounts of white smoke, mosquito truck style. i know white smoke means i'm buring coolant. my question is typically where is the problem? head gasket, something in the turbo? the truck's motor is stock as far as i know and has abot 78K on it. it is in route on a flat bed to the dealer now.
Old 06-10-2009, 03:06 PM
bonesaw26 bonesaw26 is offline
buddy of mine has the same problem what was the deal? he cant fix his
Old 06-10-2009, 03:28 PM
05powerstroke38/24s 05powerstroke38/24s is offline
had the same problem was egr cooler
Old 06-11-2009, 08:55 AM
Abrannan19 Abrannan19 is offline
see what the smoke smells like, if it burns your eyes its coolant
If it smells like coolant your EGR cooler is shot.
Old 06-11-2009, 09:30 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
egr cooler blown, make sure you replace the oil cooler to , usually is the cause , and for the record , head gaskets dont cause coolant into the cylinders on a 6.0 engine , just will generally puke out of the reservoir
Old 07-02-2009, 04:10 PM
fordoffroader101 fordoffroader101 is offline
i had that same problem when my egr vavle went out. try getting that replaced
Old 07-02-2009, 04:19 PM
boschert_72 boschert_72 is offline
Deja vu.....
