New 6.0 required:$17,000.00 - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-29-2007, 03:47 PM Thread Starter
I own 2004 6.0 4X4, no mods, changed oil every 3,000 miles, serviced at recommended intervals. My first problem occurred at 55,00 miles when the EGR valve had to be repalced.At 100,994 miles(994 over warranty) I noticed steam from the exhuast and a sudden increase in engine temp. I thought I had blown a head gasket. The dealer diagnosed as a failed EGR cooler. After picking up the truck I noticed a strange vibration at high RPM. After driving the truck approx 500 miles I also lost 3/4 gallons of coolant with no signs of external leakage. There was no sign of coolant in the oil or vice versa. Engine ran fine. Brought truck back to dealer. The vibration was due to the tech shearing off bolts to the fan while he was trying to change the fan clutch( they had determined it wasn't working on the previous trip). He failed to tell anyone this. They could not find a leak, they simply performed a diagnostic and visually inpected the engine. They did not perforn TSB 06-3-8. ( I learned of this TSB from your site, thanks much!) They stated I was overfilling the tank(NOT).Approx 2 months later the check engine light goes on( I,m still having to add coolant, the rate fluctuating depending on truck usage). The code the dealer finds is P0299 which they say indicates the turbo is dirty or rusted and may need replacement, but it is safe to drive. They reset the light and it never comes back on. 4 months after the initial repair I again have steam coming from the exhuast. This time I take the truck to a different dealer. They find not only ANOTHER BAD EGR COOLER but the head gaskets are bad, scored #2 & #7 cylinders, the exhuast manifold badly rusted and the turbo rusted as well. The original dealer, of course, takes no blame for thier failure to do thier job. If they had done the TSB I would most likely be looking at a head job and not a new motor. I'm now waiting to hear from FMC district rep to see if they will help cover some of the cost( I know, good luck). Truck ran great right to the end of the warranty. New engine is warranted for 2 years/unlimited miles.
menzawheel is offline
post #2 of 21 Old 01-29-2007, 03:53 PM
im fat and ugly
stump0331's Avatar
awe man i hate to hear that, hope fully the rep will see what the idiots failed to do and help ya out
2004 Excursion
stump0331 is offline
post #3 of 21 Old 01-29-2007, 04:05 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Dude, that sux....Hopefully FoMoCo will see the first dealer goof, and make good on it all...keep us informed!
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #4 of 21 Old 01-29-2007, 04:05 PM
Big Tone's Avatar
Quoted: 2 Post(s)
Just asking, is 17,000 what they charged!
Would think you could get parts yourself, and pay someone to install and save about 8 grand.
Big Tone is offline
post #5 of 21 Old 01-29-2007, 04:57 PM
duct tape & zip ties
bigcountrysg's Avatar
even if he bought parts and tools and equipment I think he could do the job himself and save money. Good luck with Ford Motor Co.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #6 of 21 Old 01-29-2007, 05:54 PM
Resident Tire Smoker
raveer2000's Avatar
Document Document Document...
Everything thing that took place with this dealer.. Take pics if possible of the sheered bolts.. Having your ducks in a row definetly will help with a ford rep.
Looking to buy again
raveer2000 is offline
post #7 of 21 Old 01-29-2007, 07:37 PM
Send a message via AIM to Diesel Nut
Good luck. I hope FMC takes care of you, but with all the issues FMC is having with IH, it may be some time before you get anything out of the deal. I agree, there has to be a rolled pickup somewhere nearby with a good motor. While its out check everything out real good and install a set of ARP Head Studs and you should be much better off than a huge bill like that.
Once again, good luck!
Diesel Nut is offline
post #8 of 21 Old 01-29-2007, 08:23 PM
If you are well documented, I cannot believe you will not get some relief from the Lemon Laws or Ford...... It sounds like the Dealer has a "rectal cranial inversion" and should be liable for some compensation or a major discount on a new engine....
Lone Ranger is offline
post #9 of 21 Old 01-30-2007, 04:23 PM Thread Starter
I am definitly well documented. I have a copy of all work orders, even the one where they said the reason I didn't get billed for a new fan clutch(after first visit) was due to the fact the " tech confused my truck with another one in the shop". Its on the work order! And to add insult to injury, the 3 new truck motors showed up ( there is two other 6.0s parked next to mine in the shop) and were only able to complete one installation (of course not mine) becuase two engines arrived with warped intake manifolds!!
post #10 of 21 Old 04-11-2007, 10:43 AM
Michelle's Avatar
Send a message via AIM to Michelle
Question Re: Starting to have exact problems
I just had some work done on my truck because I noticed that the back side of my turbo was starting to leak oil, I took it to the dealership and they said the house and duck work needed to be replaced. As soon as I got my truck back I noticed that driving it under a load especially pulling hills I could smell antifreeze I can not find a leak but I keep the reservoir filled up. Today now the check eng. light comes on and when you put the engine under a load it trys to die and smokes and it seems like the EGR valve sensor, but now where the heck is the antifreeze going and why can i smell it and never find it? Any suggestions before I take it to the dealership since they can not seem to take the truck in till monday. Thank god I bought the extended warranty, truck only has less than 63,000 on it.
Michelle is offline
