I am very scared!! - Ford Powerstroke Diesel Forum
Old 05-21-2009, 07:18 PM
I am very scared!!
Ok so I just got on this forum today for the first time and I hate to say this but the only reason I even started looking at a powerstroke forum to join is simply because I am worried. I just bought an 04 f250 harley davidson edition 6.0 diesel And it seems to have problems. I blow white smoke only in the morning for about 30 seconds. This morning I got an injector #7 code for like 2 mins. then went away. It always pulls an egr code so yesterday i pulled the egr wich by the way is a pain and cleaned it. Didnt help actually got worse. So I unplugged the egr all together. Is that bad? I have no CES light but it still worries me. I have to deliver a boat tomorrow. ( I own Lavro Drift Boats) not very profitable in a market like this But anyways im driving to oregon from seattle with a light load should I be worried? I had no idea about the 6.0 being such a POS before I got it. I got the truck for 22,900 with 50k on it. Is this thing worth keeping. It has a minor amount of coolant around the cap of the res. tank. Thanks for any help what so ever.
Old 05-21-2009, 07:30 PM
Is the white smoke only on the first start up or all through out the day? Also, does the truck miss or shutter when you are at a cruising speed? And welcome to the Org. Hang around and you will me some nice people and learn a lot about your truck
Old 05-21-2009, 07:51 PM
it does shutter at cruising speeds once in a while. like if I am going at at like 65mph in cruise control up a gradual hill it will shutter. And it only has white smoke in the morning for about 2 mins and it acts like it wont go until the smoke clears up.
Old 05-21-2009, 08:09 PM
That is a bad injector or two. Have you also seen lower mileage?
Old 05-21-2009, 08:19 PM
I have. Persay the heasd gasket is bad how will I find that out? And is it safe to drive with injectors going bad? thanks
Old 05-22-2009, 04:08 AM
I just had the exact same symptoms. I had 2 bad injectors, got it back yesterday, and the truck is smooth as silk.
If you had a blown head gasket, the truck would be overheating...
Old 05-22-2009, 04:20 AM
Almostdunfukinwidit
Your number 7 injector is failing. Take it in get it done. And no you shouldnt drive it like that for long if possible
