help identifying elec connector - Ford Powerstroke Diesel Forum
Old 05-21-2009, 09:26 AM
Truck is 2004. Looking at the top of the engine with 12’oclock being where the turbo is there is a cream colored electrical connector about 1” from the oil filter housing at about the 10 o’clock position.
Does anyone know what this plug is for?
I ask because during reassembly the clip was brittle and snapped off. Right now I fashioned a clamp that picks up from a oil filter housing bolt and captures that connector but I don’t trust it. I’m planning on super gluing the connector together and adding a pigtail to the harness.
In the mean time if I run into an engine problem I want to be able to know if it’s possibly related to that loose connector.
Thanks
Old 05-21-2009, 09:58 AM
if your worried about it just take some elec tape or a elec zip tie and secure it that way. you never know when you gotta pull it apart.
Old 05-21-2009, 10:16 AM
DBM DBM is offline
I think that is the EOP switch (engine oil pressure) there are two in that area, the other one is engine oil temp sensor. The EOP runs the oil pressure gauge.
Old 05-21-2009, 10:35 AM
Cool, thanks. Maybe I'll just unplug it while it's running and see what happens.
