white smoke
I have an issue with my truck, wondering if anyone can provide some insight. Driving it across the country last week I puked a good amount of coolant (i probably put back in over a gallon when it was all said and done) and also at the same time I discovered a crack in an expansion joint on my turbo y-pipe. Right before it puked I was driving roughly 70mph in the hills of South Dakota against a 50mph headwind, which I obviously didn't realize were that strong at the time. Since I filled the degauss bottle up to the correct level, I have not lost any coolant. It has stayed at the same level for basically the last week. However, each morning when I start it up cold it blows some white smoke. One morning it was very heavy billowing out for a couple minutes and the other mornings it is just barely even noticable. Truck drives fine and has good power, the crack in y-pipe causes a whistle around 20+ psi of boost but other than that it seems perfectly fine while driving it. No coolant is being lost, oil looks good and is staying steady also. I have an egr delete so its not a bad egr cooler.
Does anyone have any ideas of what is causing this??? maybe a very very slight amount of oil or coolant that is leaking down there as it sits all night but is not noticeable to the naked eye when I check the level? Thanks in advance. |
any ideas??
Could be a blown head gasket. Could be a cracked head. Also your EGR delete could have failed. If it's just the cheezy freeze plug delete, then I'd also check that. Any other symptoms?
no other symptoms. After it puked I drove another 1200 miles and it drove fine, I drove it pretty easy because I just wanted to make it but the fact that I haven't lost any coolant leads me to believe its not a bad headgasket or cracked head. Wouldn't I be burning it up as I drive and see the the coolant level dropping?
Ya most likely you would be still using coolant. Still wonder about the EGR delete. What kind did you use?
i did the egr delete myself and welded it. What are you thinking would have failed on it that would cause the smoke?
did you weld both ends? Also one of the funtions of the EGR is to cool combustion temperatures. Not having one could lead to increased engine temperature.
What about a sketchy T-stat? Also I had a 7.3 that made a bunch of white smoke because it had an exhaust leak on the drivers side exhaust manifold. |
