2 Minor Issues - Ford Powerstroke Diesel Forum
Old 05-13-2009, 12:04 PM
2 Minor Issues
I have two small things that im trying to figure out. First, sometimes when i crank my truck it will spin a couple times and fire right up to the idel. Other times it will spin over a slight bit longer and fire at a very low RPM and make its way up to idle, only take a couple secs but its very noticeable. Any ideas.
Second, My brother in law was following me the other day and when i got on it to pass some one he said a small puff of blue smoke came out and it did it a couple times when passing.
Old 05-14-2009, 05:41 AM
No one has any tips?
Old 05-14-2009, 05:51 AM
Send a message via ICQ to KyBlue Send a message via AIM to KyBlue
my 04 with the Six Oh did the startup and low crappy idle the other day for the first time... Has'nt done it since, and i was low on fuel, just assumed it was related to that. I dunno. Sorry any help I know...
Old 05-14-2009, 05:54 AM
Chapter Director
my truck dose the same thing starting i think it might have something to do with having original glow plugs i am going to be changing mine soon.
blue smoke from i understand is oil. i know for a 6.0 it wouldn't be out of the ordinary to see a bad turbo. you could even pull the intake tube at the turbo inlet and see if there is heavy oil residue.
Old 05-27-2009, 08:35 AM
My intake tubes look clean.
I guess it might be the Glow plugs. It usually wont do it if its really warm but if its been sitting for a while it will do it. Is it a big job to replace the glow plugs? Is there a better aftermarket set up that is recomended? Thanks
Old 05-27-2009, 09:10 AM
it is not glowplugs,you need to hook it up to a scanner and check it while cranking,could be icp or maybe hpop orings leaking who knows without scanner.and the blue smoke could also be a number of things,orings on injectors leaking,turbo like said above.
Old 05-27-2009, 11:23 AM
What would i need to watch on the scanner. I have access to a Snap-on unit.
Old 05-27-2009, 01:04 PM
you need to keep an eye on your icp pressure while cranking and see if it is working properly,it has been awile since i had one hooked on a 6oh.you can also check for codes you could also buzz injectors and cont.test to see if you have any other issues.that is just were i would start especially if you have a scanner handy that you can use.
Old 05-27-2009, 01:11 PM
Ok thanks. I may hook it up tonight to see what the ICP Pressure is. What should it be when cranking?
Old 05-27-2009, 01:17 PM
i think it needs 500,that should be about right.like i said it have been awile.i have also seen that problem with 6.0 that only need a new reflash from the dealer so that might also be a option if you find nothing else.
