low power - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-11-2009, 11:32 AM Thread Starter
low power
I have an 06 F-250 6.0 automatic trans. Lately i've been experiencing low power and poor fuel milage. Took it to dealer and they said they could not find any problems. No codes are present. The truck wont hardly hold overdrive up hill pulling a 16ft jon boat. I told them I suspected the veins in the turbo were sticking but they said without any codes they could not do anything about it. Not sure if they even checked the turbo or not. Fuel filters were also just changed. Below 2000rpm the truck will only make 10psi of boost.Top end still feels pretty strong. Any suggestions?
catpower1410 is offline
post #2 of 2 Old 05-11-2009, 11:41 AM
Chapter Director
psd_va's Avatar
if you get a chance go out to a fairly non busy road and try to go from a stop to full throttle and see what kind of response you get. if it is real sluggish then your veins could be stuck open. i even had a problem the lower rpm i had decent power but any thing over about 2200 then it would fall on its face found out i had water in the tank from a ****ty gas station that i will never go back to.
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
