2005 6.0 powerstroke, need a little help?????
Alright well i have a 2005 f350 6.0 powerstroke i am having a few issues with it, i just got the truck a couple of weeks ago and out of the blue one morning it started to have a skip until its completely warm does it clear up, also it started to backfire/pop out the exauhst if you floor it and let off real quick it does this when the motor is warm and cold, also pops out the exhaust when coasting just not as bad as when you get on it. The check engine light came on the same time and the code i got is P0271 which is the #4 injector circuit high, so the main question is, is number 4 injector bad/need replacement or is there somthing else wrong??????????
Thanks alot for any help
