**HELP** Cant get EGR out ! - Ford Powerstroke Diesel Forum
Old 05-02-2009, 09:38 AM
I was gonna take my egr out and clean it but it wont pull out,
i can get it to turn about a 1/4 inch but wont pull out, i even
tried to pull it out with channel locks.
i did take the 2 bolts out (so u know)
So what gives ?
thanks for the help,
05 f-350 6.0
Old 05-02-2009, 10:02 AM
I don't know nuttin....
wiggle and pull up with the channel locks...it will come out. Get up there on yours knees right above it so you get the best possible leverage.
Wiggle and pull.
Old 05-02-2009, 10:04 AM
Thanks, i was just scared i would screw something up.
Old 05-02-2009, 10:07 AM
nope, it has two very stubborn rubber o rings aroiund it. Might even spray some penatrating oil down around it, i bet that would help a lot. Got any PB Blaster?
Old 05-02-2009, 10:21 AM
Rob Rob is offline
if you can, put a common screwdriver between the valve and the mating surface and carefully twist it. It will help raise the valve out of the hole. Looking at the front, you can fit a screwdrver under some lines and be able to twist.
Old 05-02-2009, 12:14 PM
a slide hammer makes it a pretty simple removal also
Old 05-02-2009, 01:55 PM
Got it out & got it clean,
thanks for all the help guys, love this site !!!
Old 05-02-2009, 03:51 PM
Glad to hear it...no problem
Old 05-02-2009, 04:09 PM
285,261,190
Glad you got it out. They can be a real pain sometimes
