2003 6.0 liter problems
Ok heres the scoop. I have an 03 Excursion with 84k.
First the other morning i went to start it and it just keep cranking over. So i stop and tried again and it finally started. I figured becuase it was cold that was it. Then i went to the gas station and it did it to me again and the truck was already warm. Any Ideas? Second and this hasnt happend in a while but i was crusing at about 55mph when all of a sudden the tack and speedo jumped all the way and i lost power and throttle but the truck did not die then it came back. Some one please help. |
Check oil level.
my atruck has the same starting problem my mechanic took it iin and found out at a cold start i only have about 15 psi and at hot i have no pressure at idle but when it runs its fine and my oil gauge on the console goes of at idle then jumps up when i acclerate its a possible worn main bearing for me with 200,000 miles on the truck as well
