Lots of white smoke at start
I have an '05 350 and its starts real rough and blows alot of white smoke but once it warms up it goes away. Not sure why its doing this. My other truck needed a new egr cooler and was smoking but that was a consistant cloud of white smoke. Does anyone have an idea what could be causing this?
White smoke on a cold start that clears is generally unburnt fuel from a bad injector(s). When you get up to temp a lot of the time it goes away. Have it checked out.
Not 100% sure that's your problem, but you'll know more once you get a good scan on it. |
So , a diesel shouldn't blow ANY smoke ?
could also be a glow plug issue. what are the temps where your from? he was not saying that. but when a truck starts rough and blows LOTs of white smoke something is generally wrong. |
mine does it when its really cold like below 0* or if it has sat for a few days in a row
Im from the northeast it was 90 last weekend and was still blowing so much smoke I couldn't see past the truck. Im going to take it in and get some warranty work done. Thanks
Mine will do it if its cooler and depending on the moisture content of the air. Generally mine will not blow any smoke
