Truck has a mind of its own? help - Ford Powerstroke Diesel Forum
Old 04-26-2009, 02:13 PM
So it started a couple of weeks ago. I was driving down the road and all of a sudden the truck decides to just give it self a little bit of throttle. This got my attention real quick. The truck belches black smoke every time it does this. The cel came on every once in a while but all this week it has been on, just haven't had time to fix it. The idle is also jacked up, its just fine at start up but after a minute it jumps up to 1200 rpms for a couple of seconds and settles down to the 800's which is higher than normal.
My truck had an edge box on it till today. I thought maybe it was the problem, but it wasn't. I took the box off and started my truck back up and it idled fine so i decided to take a test drive. This was a bad move. The truck ran fine for about a mile. As i was coming to a stop sign the truck just shut off. Started back up but as i gave it some throttle in neutral it was throwing a little bit off black smoke.
Problem number 2 is as i left the stop sign i went about 2 more miles and the truck started shifting funny. it didn't want to shift, hanging in between gears and the tow haul light started flashing. never had any problems with my truck ever till now. This kind of has me all bummed out need all the help i can get thanks.
Old 04-26-2009, 02:37 PM
ok get the codes pulled and post them here
Old 04-26-2009, 03:23 PM
Decided to try and drive it around to see if it would learn to shift with out the edge box. It does great for a minute then all of a sudden it doesn't want to shift into 3rd and locks out overdrive, then the tow haul light flashes. If i put the truck in tow haul mode when i first start it up the thing shifts fine and overdrive is there. going to get the codes pulled tomorrow if i can.
Old 04-26-2009, 03:25 PM
Can you not get the codes from the Edge? On mine you can but its just the Insight
Old 04-26-2009, 03:26 PM
The "run away" problem is almost certainly a bad ICP sensor. It is probably causing the dieing at idle problem too. And furthermore, it might be causing your tranny to go into limp mode because of the engine not running right.
Get your codes pulled and let us know..
Old 04-26-2009, 03:27 PM
it sounds like there is a serious issue. knowing the codes will help to steer ya in the right direction to get it repaired.
Old 04-26-2009, 03:32 PM
If it aint a CAT itsa DOG
I agree with Eli, my bro's 04 did the same thing. The ICP sensor went out and his truck would just take off going down the freeway or sitting at a light. It was kinda dangerous. he had that replaced and all his problems went away.
Old 04-27-2009, 05:25 PM
Could be ICP, codes and sensor data would be great.
Old 04-30-2009, 01:48 PM
mine does the same thing but no codes no data, levels out whem you pull the ICP connector
Old 05-02-2009, 08:53 AM
Mine too, I have hears that from alot of people too. I just pop in nuetral and let it go. Good Luck
