something is wrong - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-24-2009, 09:21 AM Thread Starter
gabelnj's Avatar
something is wrong
My truck is acting up…. First, when I get on it and roll out getting the EGTs up to about 1000 it feels like the turbo is cutting out. When I role back into it the truck pours black smoke out and the turbo doesn’t spool up. Is my turbo going out or is my EGR valve clogged up. Also when I build up boost there is a humming whistle maybe even a moan, is the head and gasket issue?
2004 CC/SB 4x4
EDE 5R110 rebuild/ bulletproof
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
EDE stage one sticks with hybrids
spearco intercooler
MBRP duals... want diamond eye 4inch DP
helper bags
Stock wheels and tires
need dyno
gabelnj is offline
post #2 of 18 Old 04-24-2009, 09:23 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Is the tune stock or what?
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 18 Old 04-24-2009, 09:24 AM Thread Starter
gabelnj's Avatar
running Xstreet normally
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #4 of 18 Old 04-24-2009, 09:25 AM Thread Starter
gabelnj's Avatar
straight piped 4 inch
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #5 of 18 Old 04-24-2009, 09:28 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
reload your stock tune and run it and report back.
post #6 of 18 Old 04-24-2009, 09:29 AM Thread Starter
gabelnj's Avatar
roger wilco
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #7 of 18 Old 04-24-2009, 05:33 PM Thread Starter
gabelnj's Avatar
ok.... returned to stock and ran some errands. the turbo is still cutting out after running it hard however, no smoke (less fuel on stock tune). at highway speeds when rolling into it and building boost the truck is giving off a howl almost, not a "turbo fart".....?
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #8 of 18 Old 04-24-2009, 07:47 PM
WEWILLE's Avatar
Hows the power? The noise could be many things! I would tend to believe that the passenger side uppipe flex section is leaking, causing low boost, high egts, and smoke. But id still look into the egr valve and the turbo could be sticking as well... But id check that uppipe.
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #9 of 18 Old 04-24-2009, 08:11 PM Thread Starter
gabelnj's Avatar
with the tune loaded it still pulls really good, when the torque converter is locked up and the turbo pushes it. but then you give it more left foot and it down shifts the EGTs as usual sky rocket but it feels like it loses power. you role out after that and get back in it the turbo doesn't spool and it smokes like a steam locomotive.
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #10 of 18 Old 04-25-2009, 08:20 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
run a scan for codes on it.
