OIL UNDER TURBO? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-23-2009, 04:48 PM Thread Starter
OIL UNDER TURBO?
OK GUYS, I SEE A POOL OF OIL UNDER THE TURBO ON MY 05 F250. IT HAS 138K MILES. IS THERE AN O-RING OR SOMETHING THAT CREATES THE SEAL FROM THE OILER TO THE TURBO? ANY PICS OR INFO ON THIS MATTER WIOULD BE GREAT. I AM HAVING TO R/R BOTH UP PIPES AND Y-PIPE. SHOULD I DO THE EGR DELETE AT THIS TIME? ANY INFO/PICS ON THAT WOULD HELP TOO.. THANKS
GPATTERSON319 is offline
post #2 of 8 Old 04-23-2009, 07:34 PM
AFBLUE's Avatar
If you are pulling parts to play with the up pipe and y pipe I would sure delete or weld closed the EGR cooler. Make sure you knock flat the EGR cooler scoop in the up pipe too. If you delete the EGR you will have to be running a tuner or you will get a SES code.
The turbo oil drain is below the turbo which could be leaking.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #3 of 8 Old 04-24-2009, 08:23 AM Thread Starter
THANKS FOR THE INFO. ANYONE HAVE A LINK ON THE BLOCK-OFF PROCEDURE??
post #4 of 8 Old 04-24-2009, 08:43 AM
jroller's Avatar
Why are you SCREAMING?
4" Turbo Back, Intake, EGT/Boost Gauge, DP Tuner F5,CCV Mod, John Woods installed shift kit, Diesel Stop coolant filter, ITP Boost fooler.
" A witty saying proves nothing."
-Voltaire
jroller is offline
post #5 of 8 Old 04-24-2009, 09:15 AM
MEZ
MEZ's Avatar
lol thats funny right there... anyways my dads got a 06 6.0 and his cooler is leakin too. just on here to get some info on it and what we can do about it. any help? and will it set off a code in a 06?
2007.5 Mega Cab 6.7l CTD 4X4 6 spd., PMT, SBC 3250, EGR & Cooler Delete,
BADP 5'' Stainless, AFE Mega Cannon, Leveled, 35 BFG's,
Bushwackers, Gator Seats, Tail and Cab Lights Blacked Out
MEZ is offline
post #6 of 8 Old 04-24-2009, 06:53 PM
WEWILLE's Avatar
Theres lots of threads on egr deletes, id do a search youll find alot of info! And yes on your 06 it will set a check engine light.
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #7 of 8 Old 04-24-2009, 06:56 PM
WEWILLE's Avatar
Theres lotsw of places for oil to leak in the valley, and yes the turbo drain could be the cause it uses a couple of o-rings.
2011 Ford Edge
WEWILLE is offline
post #8 of 8 Old 04-25-2009, 10:40 AM
MEZ
MEZ's Avatar
apprecaite tha help bud
MEZ is offline
