boost drops, and can't get rpm's or power
So every once in a while while I'm driving the power drops off the map on my 04 f 250. The boost will go to 0 and my rpm's go to 1000 or so i think. I've tried mashing on the gas and eventually it will pick back up and run normal but, I'm not sure what is going on. I've also tried to let it coast and not mash on the pedal but it just seems like for some reason the turbo shuts down for a second and then comes back up.
I installed a edge juice system recently and I think that may be when the problem started. I'm going to try and remove it and see if that helps but I thought you guys might be a good resource as well. Thanks |
vanes in the turbo may need to be cleaned, some one who is more experienced in that area is sure to show up. welcome to the ORG
I have the same problem with my 04 and i have had it since i bought the truck it got worse when i chipped it and i talked to a few people i unplugged my egr valve and have not had the problem since
i would point toward egr is full of carbon.. if you have the edge incab unit check to see if there are any codes... if you get a egr range/performance... good chance you need to clean/replace the egr valve.. super easy right next to oil filter
