Got a "miss" problem
Got a 2003 Excursion 6.0 with Banks Power Pack Kit. When driving under normal to lower speeds/rpm's I get what feels like a "miss". It will typically happen on an incline at lower rpm's with light acceleration. Don't notice any smoke when it happens and seems to go away if I let up on the accelorator and then get back on it. I had a EGR and P132B codes. I replaced the EGR and now only have the P132B code. Is this a injector issue?
May have found the problem. The bottom of the intake hose slid off the air cleaner box. I put it back on and gave it a run. So far I have not been able to reproduce the problem and the P132B has not come back yet. We will see.
Reason: Problem resolved?
