Keep Blowing 50amp IDM fuse. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-07-2009, 07:15 PM Thread Starter
Unhappy Keep Blowing 50amp IDM fuse.
I just finished removing a power code remote start from my 2006 F250 Gas and installed it into my 2005 F350 6.0L Diesel. While I was testing it I had it running on the key and it stalled without any reason. Upon inspection I found the 50amp IDM fuse blown. I remove the remote start and it still blows the fuse as soon as I turn the ignition on. Any Ideas?
Elkaholic is offline
post #2 of 2 Old 06-17-2009, 07:00 PM
50 AMP IDM FUSE
I have a 2004 6.0 diesel with a similar problem.... when I (out of a habit of starting a gas engine) immediately try to start the truck I will blow the 50amp fuse. It is random and only seems to happen about once a month.
I also put a remote starter on and can not remember if it happened before the install.
Did you have any success in correcting your problem???
JLHARLOW is offline
