Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 04-05-2009, 05:34 PM
fasthawk fasthawk is offline
anti freeze smell/leak ?
first post here, but have done reseach here for about a year.took freinds 32 ft twin big block boat out today and on the way home today could smell anti freeze, opened the hood saw anti freeze by the m/c noticed it looked like the cap for coolant was were it was coming from, took it loose had a lot of pressure on it. is this a sign of head gasket failure or i had also read here that it could be a egr promblem.what about a cap. this is a 03 6.0 excursion with about 130k on it, also it has no excesive smoke out the exhaust.thanks for any help here.
Old 04-05-2009, 05:49 PM
twoicebergs twoicebergs is offline
Sounds like puking 101. Must be spring-break
Without the temperature (outside and EGT), speed, weight, wind, ECM tuning, and boost info it is tough to troubleshoot. As you said you have been lurking, might be time for an EGR cooler test or just watch what happens over the next few weeks with other driving.
Old 04-05-2009, 06:18 PM
we ran about 70 on the highway , i think isaw about 22 lbs boost weight is between 8500 to 10500 plus the truck,dont no what turning it has but it was on the 2nd setting for towing and around 70 degrees not much wind.dont think it has the egt hooked up but the engine temp was 212 degrees. the spring break thing was friday night and he was still recovering.
Old 04-05-2009, 06:33 PM
TommyBoy#1 TommyBoy#1 is offline
well to double check where its coming from have it checked with a coolant system pressurizer i dont know any other way to be sure where its coming from 100% with out that ive used mine hundreds of times
Old 04-05-2009, 06:57 PM
doubledrop doubledrop is offline
looks like either your EGR cooler may be going or your a head gasket issue. When i smelled coolant it was my egr and oil coolers, i started getting the tea kettle whistle when i blew my headgaskets.
Old 04-05-2009, 07:03 PM
dzchey21 dzchey21 is offline
I think there is a dye you can put in the cooling system that will turn colors if there is compression in the cooling system. I might be wrong though but i would say egr or head gaskets too.
Old 04-06-2009, 04:48 AM
we were thinking head gaskets to.but were looking for other options as i dont know a hole lot about deisiels,but mess with gas motors all the time
Old 04-06-2009, 05:36 AM
03f250stroke 03f250stroke is offline
its hard to actually point the problem. you were pulling a big load with a stock truck, it could have just been puking because of the cooler.
for example my truck is studded and i have a full EGR delete and on the dyno or at the track it will puke sometimes. if i drive the truck for a few hours and stop i may have a little coolant around the cap as well. could be as simple as a $9.00 cap replacement
