EGR problem!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-31-2009, 06:40 PM Thread Starter
EGR problem!!!
I bought the edge juice with additude module for my 2006 6.0. the service engine light came on and the scan came up that the egr valve was stuck open. I took it to ford they replaced the egr valve and a sensor. I put the edge module back in and it imediately coded out saying the egr valve is stuck open again. Also im getting 8 miles to the gallon. Anyone have any idea what the problem is?
sobrien1130 is offline
post #2 of 13 Old 03-31-2009, 06:47 PM
troid123's Avatar
Send a message via AIM to troid123
get rid of edge products...
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #3 of 13 Old 03-31-2009, 06:50 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
If the intake passages are carboned up severely, all it takes is for a loose piece of residual carbon to get lodged into the valve, and you'll have the same problem again. I have had my fair share of bad-out-of-box EGR valves in my experience. There is a specific build date for suspect bad EGR valves that Ford released an internal special service message warning dealers about. I don't remember the build date off the top of my head. Inspect the new EGR valve for a pink dot on one side, and a smaller silver dot on the other, to verify that the EGR valve installed on your truck is not within the suspect bad build date.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 13 Old 03-31-2009, 07:13 PM Thread Starter
You think it has anything to do with the edge module and im getting horrible gas mileage.
post #5 of 13 Old 03-31-2009, 07:19 PM
hoosier golfer's Avatar
it's not the edge causing the poor MPG. My truck had one on it before I got my SCT & I would get 15 MPG city and 18 MPG Highway. Just sounds like your EGR. I'd recommend at least blocking it off if not deleting it all together
~Adam~
2006 King Ranch
~Other Toys~ 05 Ranger 520VX Commanche 225 HP VMAX HPDI !!
~Lots Of Guns & Custom Knives~
hoosier golfer is offline
post #6 of 13 Old 03-31-2009, 07:20 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
I highly doubt it, but it doesn't hurt to get rid of it. The first step is to bring it back to stock calibration. The next step is to evaluate your usage. These engines do not take well to extended idling of the engine or frequent short distance trips. Using good quality fuel also helps to reduce carbon buildup, along with Ford's PM-22-B cetane booster additive. These engines need to run fuel with cetane rating in the 40s, to run at its best.
m-chan68 is offline
post #7 of 13 Old 03-31-2009, 07:23 PM
I actuall see better MPG out of my truck when running a fuel that has a rating of 500 PPM Or when I run Schaeffers Soy Shield Diesel Additive I have seen a 2-3MPG Increase.
~Adam~
2006 King Ranch
post #8 of 13 Old 03-31-2009, 07:25 PM Thread Starter
How do I block it off and will that cause anymore problems.
post #9 of 13 Old 04-01-2009, 07:07 AM
So if it has the pink and silver dots it means possibly a defective EGR valve or if it has them it means ok??.
I1.
Ignorant1 is offline
post #10 of 13 Old 04-02-2009, 10:25 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
I1.
If it has both dots, it means the valve IS the updated unit.
m-chan68 is offline
