6.0 blue smoke at idle and taking off? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-29-2009, 10:03 AM Thread Starter
82,000 miles???
thing runs great, its all stock with zoodad and a straight pipe exhaust.
I noticed it I think after I took the kitty out of the exhaust?
usually at cold idle it smoked blue, and the first taking off out of the driveway. After it warms up I think its fine.
Think I have a turbo seal going bad? I do alot of highway driving sometimes when I take the rig to work, between 2200-2500 rpm depending on traffic.
thanks!
pushinlsteg is offline
post #2 of 17 Old 03-29-2009, 10:43 AM
03f250stroke's Avatar
does it run rough when you first start it up..shaking, chugging, anything like that. it could be an injector issues, if the turbo seals went bad you would most likely be able to see some oil in the down pipe. check there first and see if its dry or wet
-Evan
6.HO
tuned by Eric
12.3
Originally Posted by shu873 View Post
Yeah, but your trucks a freak of nature...
03f250stroke is offline
post #3 of 17 Old 03-29-2009, 10:52 AM
thats bad considering blue means oil hopefully theres no compression issues
TommyBoy#1 is offline
post #4 of 17 Old 03-29-2009, 11:00 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Usually when an oil seal is going in the turbo you will notice alot of black smoke out the tailpipe.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 17 Old 03-29-2009, 09:02 PM Thread Starter
its very subtle on the cold start, very faint fog of blue smoke coming out. There is no shaking or anything, very smooth normal cold start up.
after its warm there is no more smoking.
post #6 of 17 Old 03-29-2009, 09:22 PM
FastFocus's Avatar
when mine had blown HG's it did this when it was cold outside. new head gaskets and it doesn't do it at all anymore.
-Aaron
'01 BMW ///M3 - New Toy
'07 F-250 PowerStroke - 5" MBRP Straight Pipe, Edge Insight, Eric Tuned SCT, HID's, 2.5" Newton Lift w/ 4" rear block and Icon Caster Sleeves, Bilstein 5100's, 18" XD Monster's w/35" Toyo M/T.
'17 Chevy Malibu - DD and Company Vehicle
FastFocus is offline
post #7 of 17 Old 03-30-2009, 06:17 AM
NEWT92's Avatar
Thats interesting, my 05 had had a blue smoke issue since 5000 miles. Had the dealer look at it several times and found nothing. They even tryed to blame it on the Air Raid intake.
1968 Chevy Impala Custom Coupe ZZ4 350 700R4 trans 3.55 Posi
2003 F250 XLT 2wd. R/C LWB 7.3 Auto Volant Air Intake 4" Turbo Back Exhaust
2008 F250 King Ranch 2wd Crew Cab Short Bed V10 Auto
NEWT92 is offline
post #8 of 17 Old 03-30-2009, 09:17 AM Thread Starter
well i see no real issues with the truck, thats a relief though NEWT92, blown headgaskets? makes no sense really. I should at least have a overheating issue which I dont if I had blown head gaskets.
post #9 of 17 Old 03-30-2009, 11:44 AM
FastFocus's Avatar
wrong, both my HG's were blown to kingdom come and i never overheated, temperature never even rose above 190.
-Aaron
post #10 of 17 Old 09-11-2010, 01:40 PM
Kwattro's Avatar
Question
82,000 miles???
thanks!
Same on my truck. Absolutely no smoke until I removed the cat. When I cold start the truck it blows just a slight wisp of light blue smoke until it's warm, then it goes away completely. Otherwise the truck starts and runs great. There is no oil smell in the smoke at all. All fluids normal, no fuel in the oil. The only thing I think could be a contributing factor is the 2-stroke oil I use each fuel up. The next couple of tanks I won't use the oil and will report back.
The El Cheapo Cooling Filtration DIY - It works!
_________________________________________________
-= 2006 F-350 SuperCrew 4x4 6.0L PSD =-
IIS Stage 1 Turbo, Warren Diesel 155cc/0% Injectors,
Swamps 58v FICM, PHP Atlas 40 Tune, PHP Gryphon Programmer,
5" Diamond Eye Exhaust, DieselSite Coolant Filter,
Knockoff EGR Delete, ARP studs, 33" Toyo MT's
Kwattro is offline
