6.0 Head Resurfacing? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-16-2009, 08:25 PM Thread Starter
AFBLUE's Avatar
Getting all my facts straight before I go into dealer to get head gaskets, studs, and welded EGR/upipe installed.
I have seen a few cases on here where people have gone to dealer for head studs and still are having issues, Degas bottle Puking, and some extreme cases of washing the cylinder walls from coolant and needing a new motor. What issues have people had so I know that I am going to the dealer once and only once.
What are the Head spec tolerance that I need to hear from the tech to know that they heads are as flat as they need to be so they gaskets will seal correctly with the ARP studs?
What is the technical stance on surfacing the heads to make them flat?
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #2 of 12 Old 03-16-2009, 08:41 PM
Mike Hickman's Avatar
WE talked about this already but I wanted to just say it's a must to get them machined !! Just cause they slap a new set on does not mean they are even or true .This is what i was told by good friends and the service tech that just did my heads with A1's :} also My daughters Boyfriend got his back to day getting A1's installed ..
Hope some one else can chime in with better info !!
Give TSD a ring they will give you all the info you need as to why ...
Oh, your friend has all the info he asked for !!
TRUCK WAS STOLEN NOW IS SOLD 2006 Lariat FX4 F-350
7" BDS Lift
SCT Xcal3 Tuned By Truck Source Diesel TSD with SPD !
Triple pod Auto Meters
4" MBRP Exhaust
Straight piped Turbo back
Zoodad Mod
325/65/18 13.50's MTZ
18x10 Mickey Thompson Bead Locks
A1 H11 Studs Head Bolts/Studded
EGR Deleted
Harley HeadLights
S&B Intake
Mike Hickman is offline
post #3 of 12 Old 03-16-2009, 08:41 PM
I'm one of those that had puking with studs. When you get the studs demand new heads, oil cooler, and EGR cooler. If they don't give you new heads then get them magnaflux to check for warpage and cracks. I wouldn't bother with resurfacing the heads just try to get new ones.
2005F250 is offline
post #4 of 12 Old 03-16-2009, 08:45 PM Thread Starter
AFBLUE's Avatar
Yeah I know you are the one that brought it up and it has me a bit of concern now. If they are not willing to let me have the heads checked by a machine shop I am going to politely ask if I can go to your guy. What are A1s? are they bolts or Studs like ARP?
Edit: I just looked them up they are H-11 tool steel, very strong, but I have read they have no give so they may eventually fail being brittle.
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #5 of 12 Old 03-16-2009, 08:47 PM Thread Starter
AFBLUE's Avatar
Yeah I have been reading some of your threads, and your outcome has me downright freaked out.
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #6 of 12 Old 03-16-2009, 08:50 PM
A1's are rated at 2200 and arp is rated at 1800 strength they will cost more to. From what I was told they are reusable if needed and are stonger ..
7" BDS Lift
4" MBRP Exhaust
Zoodad Mod
EGR Deleted
Harley HeadLights
S&B Intake
post #7 of 12 Old 03-16-2009, 08:58 PM Thread Starter
AFBLUE's Avatar
I think ARP are reusable too, they have a 180,000 yield which is 75% of tensile strength so they are rated at 220,000. Surely not quite as strong as H-11/A1 but also more forgiving...
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #8 of 12 Old 03-16-2009, 09:02 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
As per Ford TSB article 06-21-10, cylinder head flatness is to be checked at all 13 spots in the illustration below. Per the TSB, flatness is to be no greater than 0.002" out-of-flat. Ford does NOT endorse resurfacing the head.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #9 of 12 Old 03-16-2009, 09:02 PM
If anything comes up let me know or you can get the info for the guy I used from your friend that I sent the PM to.
7" BDS Lift
4" MBRP Exhaust
Zoodad Mod
EGR Deleted
Harley HeadLights
S&B Intake
post #10 of 12 Old 03-16-2009, 09:19 PM Thread Starter
AFBLUE's Avatar
Ford does not endorse, but what is the honest Tech background for head resurfacing? and how flat the heads need to be. Are people having issues because the heads have not been measured correctly?
ARP studs are torqued to 245 ft lbs, what are the stock head bolts torqued to? and can the gaskets handle the extra torque following that spec of .002"?
How severe do cases get of head gasket failure when the cylinders get washed from coolant getting into combustion chamber?
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
