'04 with no oil pressure at idle - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-14-2009, 05:51 PM Thread Starter
I walked out yesterday morning to start the excursion and it was very hard to start. (lots of cranking) After giving it a little gas it started and seemed fine. I drove it down the street and then noticed the oil pressure gauge was not registering. If I bring the RPMs up to about 900, it pops up to normal. Take my foot off the gas and the gauge drops to nothing. This morning again hard to start but I had normal pressure until the engine warmed up and the oil thined. Than down to nothing at idle. Normal above 900 RPM. Any suggestions? Being that I know nothing about diesels, do you know of a good diesel mechanic in the Pasadena, CA area?
79howard is offline
post #2 of 19 Old 03-15-2009, 07:34 PM
cm979's Avatar
Oil Pump or the oil pressure Sensor. Not sure witch pump it could be there is two. A low pressure and a High. From what you explained it sounds like the high pressure pump.
The computer has to see 500 PSI from the pump before they crank from what I understand. The HP Pump is on the top of the motor from what I understand.
Hope that helps.
cm979 is offline
post #3 of 19 Old 03-15-2009, 09:04 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Stupid question. Are you using an aftermarket oil filter or the OEM Ford/Motorcraft FL-2016? If you are using an aftermarket oil filter, discard it and start using the OEM filters from now on.
I have had MANY trucks that have passed through my hands with the exact issue you describe being caused by the use of an aftermarket oil filter (particularly the junk ones that use the one-piece cap, necessitating you to discard the OEM cap that will have to be repurchased when you switch back to a Ford filter on your next oil change).
The last three trucks that have passed through my hands with that symptom was fixed by the replacement of the oil pressure SWITCH, NOT TO BE CONFUSED WITH THE ICP SENSOR. This would be the switch located on top of the oil cooler, next to the oil filter housing and EOT (Engine Oil Temperature) sensor. For what it's worth, the oil pressure gauge on your instrument cluster is only as good as an "idiot light". This means it reads pressure. It doesn't indicate low pressure or high pressure. If it makes you feel any better, your engine would stop running if the lube system oil pressure were starved, because it would starve the HIGH pressure oil system that controls fuel delivery at the injectors. In lamens terms, this means the engine would stop running long before engine damage could commence.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 19 Old 03-16-2009, 01:21 PM
cm979's Avatar
It could be that. I know someone who had a 05 with the same problem from what it sounds. It would turn over like crazy then sometimes it would crank sometimes not. Took it to the dealer and it was the High pressure pump. 6.0 for you who knows till you really start to dig.
cm979 is offline
post #5 of 19 Old 03-16-2009, 07:57 PM Thread Starter
Thanks for the info. I do fell better to know that it's not ruining the engine. I have it at All Time Diesel in Glendora, CA. I'll let you know what I the end result is. I just bought the thing and 3 days later this happens. Glad I bought an extended warrantee!!!
79howard is offline
post #6 of 19 Old 03-16-2009, 08:01 PM Thread Starter
Thanks for the reply. It always cranks and it always starts. it just takes alot of cranking until it finally starts. Once it starts it runs great except for the oil pressure gauge. I'll post a reply once I get info from the shop.
79howard is offline
post #7 of 19 Old 03-16-2009, 08:03 PM
Hows the oil level?
2005F250 is offline
post #8 of 19 Old 03-17-2009, 07:27 PM Thread Starter
Originally Posted by 2005F250 View Post
Hows the oil level?
Oil is full. Talked to the shop today. They've done some test and have determined that it is in the low pressure oil pump. He said that he suspects the housing has gone bad as opposed to the hardened gears but he'll find out tomorrow. I guess the housing is made of aluminium and more prone to failure. Thanks to all for you're imput. Thanks.
79howard is offline
post #9 of 19 Old 03-19-2009, 11:46 PM
78Southwind's Avatar
So what’s the verdict?
Jerry, Lisa and Roxy
78Southwind is offline
post #10 of 19 Old 08-06-2010, 10:32 PM
what was the end result? my 05 f350 is doing the same thing?
70cuda is offline
