Turbo noise
Thought I would post this up maybe you all can help? My dad has an 06 F-250 6.0. He pulls a 35ft fifth down south for the winter. He said when he was pulling a long pull up a medium grade he got a whooshing sound from the turbo! Any Ideas Im not sure if the 6.0's have a surge problem or not? His truck is stock. Thanks!
Okay just got off the horn with the ole man, and whoosing would not be the correct sound
He said it was like the turbo would race like it was coming out from under the hood! I don't know what turbo surge is, or what it sounds like, but too me that sounds like turbo surge? Is that an issue with the 6.0's? Thanks any feedback would be appreciated
could it be the fan engaging?
i believe its a "turbo fart" ask him if it happens when he is on it hard and the quickly lets out, its is normal and nothing to worry about its the turbo backpressure coming back through the intake, even the most stock of trucks can do it and its more prominent with aftermarket intakes
Actually he said it sounded like it was racing faster, so he let off the gas and it went back to normal. He said it has happend a couple of times now. Its usually when he is pushing it hard! I told him he should at the very least invest in some gauges!! I dont think it was the fan he was certain it was the turbo making the noise. I thought I read about somone saying there is a TSB for turbo surge on the 6.0 is that correct, or was it just because it was late and I was seeing things? Thanks for the input I appreciate it
sounds like to me hes hearing the electric clutch fan engaging at times ,that is when it will come on under hard pull ,i may be wrong
Im still learning these powerstrokes, so excuse my ignorance What is the fan clutch can ya explain or point me in the right direction for some info. Thanks
Completely normal, nothing to get concerned about. It's the fan engaging - I get it quite frequently pulling my 13,000Lb fiver going upgrade, or in stop/go traffic.
Okay thanks I will let him know he should be fine
Maybe I will let him know to back off on the gas!!!lol
I wouldn't worry about it, but getting good gauges is advisable. The other turbo fart noise does not occur when you are on the throttle but rather when you let of the throttle rapidly when the turbo is making signifigant boost. I don't think this is what you are experiencing. Good luck. |
