Warped block - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-04-2014, 06:50 PM Thread Starter
MooreSix0Stroker's Avatar
Garage
Warped block
Truck won't keep coolant in degas bottle. Repair shop says my block is warpped. Same shop did hg repair last Feb./ Mar 2013. How common are warpped blocks? Truck has egr delete, apr studs with sct programer on a performance tune.
John
07 F350 cc/sb Fx4 Lariat
ARP studs, OEM
head gaskets, 4" exhaust turbo back 6" tip, egr delete, BPD oil cooler and filtration, sct turner, egde insight monitor, coolant filter, high idle mod, Recon smoked mirror and cab markers
MooreSix0Stroker is offline
post #2 of 17 Old 08-04-2014, 07:02 PM
ZMANN's Avatar
Quoted: 1476 Post(s)
it happens the fix is $$
i would want to see for myself
they may be trying to point the blame somewhere else ? and if it all proves to be true and the block is warped i would question if it wasn't in the same condition the first go around
We Miss you Ronnie
ZMANN is offline
post #3 of 17 Old 08-04-2014, 07:07 PM Thread Starter
Garage
Going to get pics tomorrow. Luckily I bought an ext. Warranty on truck.
John
ARP studs, OEM
post #4 of 17 Old 08-04-2014, 07:12 PM Thread Starter
Garage
What are some other parts I should look in to replacing or upgrade. Bpd oil cooler new stand pipes, dummy plugs,
John
ARP studs, OEM
post #5 of 17 Old 08-04-2014, 07:16 PM
ZMANN's Avatar
they have to pull the whole motor apart to fix the block not sure what I would do at that point or if the warranty will cover it and if so just throw a short black at you
We Miss you Ronnie
ZMANN is offline
post #6 of 17 Old 08-04-2014, 07:21 PM Thread Starter
Garage
Hoping to get more questions answered tomorrow. They have pulled cab off and motor out has of noon today.
John
ARP studs, OEM
post #7 of 17 Old 08-04-2014, 10:59 PM
Jeremy@TDA's Avatar
Quoted: 113 Post(s)
Ask them how they know the block is warped. Like ZMANN said, they might be trying to throw the blame at something else when they screwed the HG install last time.
What shop?
Jeremy
Owner- The Diesel Authority
Instagram- @thedieselauthority
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@TDA is offline
post #8 of 17 Old 08-05-2014, 08:53 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
What head gaskets did they use? They can't diagnose a "warped block" without removing the heads. If it actually has a warped block, they should have told you that before they installed the heads when they did the repair.
AshevilleEngine.com is offline
post #9 of 17 Old 08-05-2014, 11:31 AM
I have to agree no competent shop is going to do heads without checking for flatness of the heads and the block that they will have to seal on.
If nothing else at least lay a straight edge on them.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #10 of 17 Old 08-05-2014, 06:17 PM Thread Starter
Garage
Saw truck today heads are removed, cab off AGAIN. They sent heads out to be pressure check. Waiting to hear back for ext. Warranty on sending out block to be check. The shop did say if they pull block that I may want to replace the main bearing at my cost. I can't believe thwy would consider reusing they. I do plan to replace the main bearing, but what else should I replace on block?
John
ARP studs, OEM
