2006 F350 6.0L Dieasal No Start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-04-2014, 12:07 PM Thread Starter
Hi there I have a 2006 Ford F350 Harley Davidson Diesal with only 77,000 kms
The truck is completely stock other than fuel filters and oil filter changes!*
My problem is about 3 weeks ago all of a sudden while leaving the gastation the truck would not start, just crank! I sprayed some "Quick Start" in the air cleaner intake and it fired up and started right away! The same problem continued only when the truck would warm up after about 10mins! When cold it would start fine!
Now the truck just cranks but when I spray the "Quick Start" it fires up but only with the throttle held down and then dies right away!*
After I spray it, it almost starts but then just continues to crank over till I spray a little again, and it does the same thing, almost starts then just continues to crank over!*
Help!!!!
Balla201 is offline
post #2 of 5 Old 08-04-2014, 01:57 PM
Starting fluid is a big No no
Useing any starting fluid is not recomended on a 6.0 bad things can happen.
You need the codes read and live data looked at. You could have oil pressure problems; fuel pressure problems; electrical problems a number of things.
Without actual data any of us are just guessing. Educated guesses but just still guesses.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
The Following User Says Thank You to dannyboy950 For This Useful Post:
Balla201 (08-04-2014)
post #3 of 5 Old 08-04-2014, 07:50 PM
snobdds's Avatar
Quoted: 9 Post(s)
Get some way to the numbers of ICP, IPR, FICM...and we can point you in the right direction.
Scanguage II is the cheapest way of obtaining these, unless you have a friend with a way. Either way, every 6.0 owner should have a set of gauges...
snobdds is offline
The Following User Says Thank You to snobdds For This Useful Post:
post #4 of 5 Old 08-04-2014, 07:56 PM Thread Starter
Thanks a lot guys, I will get more info!!!
Balla201 is offline
post #5 of 5 Old 08-05-2014, 08:21 PM Thread Starter
Codes
These are the codes that my trucks OBD2 system tested
P0261, 264,267,270,273,276,279,282
Help no start!!!!!
Balla201 is offline
