What's the max ICP pressure I should see? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-03-2014, 07:42 PM Thread Starter
casper4203's Avatar
What's the max ICP pressure I should see? When I pulled my camper home the last time, I saw ICP of 3900+psi. I wondering if this is causing a problem I'm having.
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 3 Old 08-03-2014, 10:11 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Typically, if everything is good the max is about 4,000 psi. So, 3,900 psi is pretty good. Maybe you need to tell us about you problems.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 08-04-2014, 04:11 AM Thread Starter
casper4203's Avatar
I pulled my camper 150 miles. Ran Great. The second day on vacation I broke down. Lost all my ICP pressure. Pulled the truck to the campground and had to replace an injector. The retainer clip on the top o-ring let loose. The spacer ring split in half. Pulled the camper home and it ran fine. The next day I was running an errand and the same thing happens AGAIN! On a different injector.
Now I'm trying to find just the spacer ring with no luck.
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
