Help please - Daughter's 05 blowing black smoke with loud fan like sound - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Jeremy@TDA
post #1 of 9 Old 08-03-2014, 05:45 PM Thread Starter
Just got a call from my daughter and having problems with her 05 F350 (140K or so on it). She's not driving her truck, but is following in another, both pulling heavy (8K lbs or so) trailers and its blowing black smoke. Originally, she had limp mode problems when pulling heavy trailers up hill. NC dealer replaced the EGR (that didn't help) and local dealer cleaned the turbo.
On the way to horse show, truck went into limp mode once (no CEL or ABS light like she was getting before). They shut it down and it ran fine the rest of the way (about 200 miles). No limp mode on the way home and truck seemed to be running fine. But it started blowing black smoke out the pipe up hill and is now doing it straight and level and down hill also. The person driving it says it sounds like a loud fan is running. But no limp mode at all and they are about 20 minutes from home after 250 mile run.
Any idea what the fan noise could be? I'm kind of thinking that the fan is finally working because the truck was always going into limp mode prior to getting the turbo cleaned. But first time she has pulled this trailer without truck continuously going into limp mode and in somewhat hot weather (as opposed to winter). Any suggestions would be appreciated. It does have an older Bully Dog on it - local dealer put it at minimum settings.
Thanks,
AJG
ajg617 is offline
post #2 of 9 Old 08-03-2014, 06:37 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I'm gonna bet the loud fan is just the fan due to overheating. You reeley need a monitor to pull up codes to tell for sure what is going on. Did the dealer clean the ego valve when they did the egg replacement?
I would say shut the truck down, have dinner and take it easy coming home. Then spend a couple bucks on a monitor before the truck goes boom and you spend ALOT of bucks.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Heavy_GD (08-03-2014)
post #3 of 9 Old 08-03-2014, 10:49 PM
Jeremy@TDA's Avatar
Quoted: 114 Post(s)
lol
Heavy_GD likes this.
Owner- The Diesel Authority
Instagram- @thedieselauthority
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@TDA is offline
post #4 of 9 Old 08-04-2014, 04:56 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
HAHAHA you gotta love the auto correct spelling.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 9 Old 08-05-2014, 08:03 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
It could be a bad injector dumping too much fuel in a cylinder. Don't run it like that, it can burn a piston. A computer check will show that if it's a problem.
AshevilleEngine.com is offline
post #6 of 9 Old 08-05-2014, 09:35 AM Thread Starter
Daughter stopped home today. Bully Dog logged codes P0278, P1148, and P0234. It shows max boost as 35PSI and max Pyro at 1522F. Defuel is set at 1250.
ajg617 is offline
post #7 of 9 Old 08-05-2014, 02:11 PM Thread Starter
Well, got under the hood today. Three or more holes in flex area of the driver side plastic intercooler pipe and warped air cleaner end cap (the side with the MAF sensor) on the side where there are no clips to hold it together. I can put my finger through the gap between the filter box and the end cap. Think I found the 'fan' noise.
But, worse - coolant overflow tank was empty. Took nearly a gallon of gold coolant to get it to the Min mark. No signs of leaks anywhere and there was pressure after I let the engine cool down about an hour. So now I'm wondering if the truck at some point overheated? Other than that, drove it today and it runs great.
ajg617 is offline
post #8 of 9 Old 08-05-2014, 06:46 PM
Jeremy@TDA's Avatar
Quoted: 114 Post(s)
If EGT's were at 1522 for a long period I would say it probably overheated. Is there a white looking residue around the degas cap?
Jeremy
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
post #9 of 9 Old 08-05-2014, 07:06 PM Thread Starter
Jeremy
No it was clean but I do think it may have gotten hot on a long extended climb based on how much coolant I had to put in - 3/4 gallon.
ajg617 is offline
