No boost/low boost - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-03-2014, 04:30 PM Thread Starter
BigRedPSD's Avatar
Quoted: 3 Post(s)
No boost/low boost
As the title says I'm having a low/ no boost. I just redid my heads, truck runs like a dream, except that there is a hissing noise coming from the turbo(I think). When you get on it even easy it gets louder, but it's not a poping noise it's just a loud hissing noise. I'm thinking maybe the up-pipes aren't clamped together good enough? Just wanted to through this on here and see what anyone else thought. Going to try and fix it tomorrow. Thanks in advance.
Kyle
Early 04
head studs, cat delete
egr delete, altas 40 ficm tune
sct Livewire, PHP 140 Extreme tune, afe intake
blue spring, 285-75-r17 on addict XD wheels
BigRedPSD is offline
post #2 of 5 Old 08-04-2014, 08:32 AM Thread Starter
BigRedPSD's Avatar
Quoted: 3 Post(s)
Refitting the up pipes to the turbo and I still have the hissing noise. If I unplug the vgt it's goes away what is this problem? Something with my turbo? Before I worked on it noting was wrong
Early 04
post #3 of 5 Old 08-04-2014, 11:53 AM
Seems you checked the exhaust side did you check the intake side for problems?
Loose fit, split in intake pipeing, air filter problem?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 5 Old 08-04-2014, 12:56 PM
Are you sure the flex section on the up pipes didnt go bad. Also the v band clamp for the y pipe to turbo has to be perfectly flat together or it will leak. i use a ratchet strap to the core support behind the right side head light to pul it in place before i put the v band clamp on.
KUGSS is offline
post #5 of 5 Old 08-04-2014, 02:21 PM
Lifsvr7's Avatar
Send a message via AIM to Lifsvr7 Send a message via Yahoo to Lifsvr7
I'm having the same issue (posted). I did the same thing with unplugging the turbo and it did the same thing. I was reading where the tube of the drivers side exhaust manifold becomes coked up. I unplugged that sensor as well and did the same thing. So next thing I'm gunna clean it out. U might wanna try that as well. Ppl be having the same probs as and had success with it.
2005 F250 Crew SRW
34" Nitto on 20" Moto metal
Home made EGR delete (bung & new up pipe),
Straight pipe & stacks, SCT w/ID tunes
Lifsvr7 is offline
