No start problem 6.0 2006 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-03-2014, 12:56 PM Thread Starter
Hello I'm new to this forum. I own a 2006 6.0 diesel F250. I had the injectors replaced last summer about a year ago truck ran ok for about 6 months then started running rough hard to start in winter then this past April I noticed the truck was turning the starter longer before it would start up. Then two days later I drove it a couple hours and it ran ok and parked it went out to start it and it hasn't started since. The starter spins but motor won't fire. a friend of mine put a computer on it and came up with these codes p0269, p0281, p0470, p0562, p0678, p1378, p2291, u0155 I tested the ficm and it read 48 volts and I put a new glow plug in #8. Now when I put the computer on it it comes up with zero codes. We erased the codes from the first time after we wrote them down. Any help on where I should look next would be appreciated. Jim
brickman is offline
post #2 of 4 Old 08-03-2014, 04:07 PM
willislawns's Avatar
Icp but really need more info. Try disconnecting the icp sensor.
2006 F250 CC 4X4
STOCK (EGR Delete)
133k and counting
8'2" Boss V
6 way strobes
Blue spring upgrade
5" after down pipe 6" tip no muffler
Replaced fog lights with led bar
willislawns is offline
post #3 of 4 Old 08-04-2014, 03:27 PM Thread Starter
I pulled the ICP and still no start. starter just turns over.
brickman is offline
post #4 of 4 Old 08-04-2014, 03:29 PM Thread Starter
just found the injector plug on no. 7 is not tight and pulls loose easily. Would this cause it not to fire at all.
brickman is offline
