Random Misfire w/ Bullet Proof - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 08-02-2014, 07:04 PM Thread Starter
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Dad has a 2006 with the Bullet Proof kit and ARP studs, 4 inch exhaust and custom Xtreme Race tune. Also has to updated STC fitting. A few years ago he changed oil and added 20-50 during a super hot summer. Ever since then the motor has developed a random misfire at idle and under load. Its gotten worse so he added some anti-stiction oil additive he bought and he says it has seemed to help his idle but under load it has gotten worse.
So, he has been wondering that if maybe during he was running the 20-50 oil its possible it stretched something or broke a seal with that new STC fitting or if maybe the bullet proof kit is starving the HPOP of oil. The truck never throws a code and we don't have access to a high pressure oil gauge.
Basically just trying to see if anyone else here running that kit has had any tupe of issue like this or not running it has had an issue and figured out a fix?
Thanks
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #2 of 18 Old 08-02-2014, 07:05 PM Thread Starter
scuffs *****
Tyler's Avatar
Also, it NEVER has a no start while hot issue so I assume its not sucking air.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #3 of 18 Old 08-03-2014, 06:11 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
So after adding the 20-50, it then developed the misfire? How consistent is it? Can you recreate it at low RPM's and high RPM's? Is it the same cylinder each time or does it vary? What kind of codes are you getting? Do you have access to AutoEnginuity or Ford IDS or other diagnostic tool to perform a power balance?
Also, and something that I just want to confirm... the 20-50 oil; was it rated for diesel applications?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 18 Old 08-03-2014, 06:45 AM Thread Starter
scuffs *****
Tyler's Avatar
Its somewhat consitant, it is a guarantee that it will happen every time you drive it. It happens a lot at idle, but it'll even do it winding up at WOT. Dunno if its same cylinder each time, some times its 1 cylinder and sometimes it'll drop 2 or 3 sitting at a stop light. Truck isn't throwing codes. Doesn't last long enough I guess.
As far as the 20-50 being rated for diesel I would assume. He's never done something super stupid and I think it was Rotella oil.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #5 of 18 Old 08-03-2014, 06:57 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Interesting. I would assume that it would be enough to set a power balance code especially with it being a 2006, but maybe not. I don't think it's related but what is his FICM voltage? Have you returned to stock tuning to see if it still does it?
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 18 Old 08-03-2014, 07:05 AM Thread Starter
scuffs *****
Tyler's Avatar
Oh yeah for sure. It doesn't do it as much but it still does it. He actually had to replace it once right after the rebuild we did but we checked the voltage on it and it seemed to be perfect. That was actually my first thought because it was a re-man. But yeah.
Do a lot of people run the Bullet Proof kit or is he the only person on the planet?
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #7 of 18 Old 08-03-2014, 10:13 AM Thread Starter
scuffs *****
Tyler's Avatar
Bump. Calling out you guys with Bullet Proof oil cooling systems!
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #8 of 18 Old 08-03-2014, 02:53 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
I can guarantee you that this isn't related to the BPD oil cooling system. I've been running it for over 3 years with no issues sounding like what you describe. How is it in your mind related to running the BPD kit? It sounds like you have one or more injectors going out.
You've already admitted that you don't know if the oil he put in is diesel rated and since our injectors use oil to fire, you could say that it's the oil that took out a couple of injectors...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #9 of 18 Old 08-03-2014, 03:07 PM Thread Starter
scuffs *****
Tyler's Avatar
I'm not saying it is. But anything is possible. Just gonna wait and see if the anti stiction additive helps the situation.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #10 of 18 Old 08-03-2014, 03:10 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Are these original injectors and how many miles are on them? Keep us posted on the situation with the stiction additive. Which one did you use?
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
