2006 F250 6.0L surge/misses - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-02-2014, 10:23 AM Thread Starter
I wouldn't call it a surge or miss but couldn't think of another term. When accelerator is applied and held at a certain place the rpms will drop approx. 100 rpms. I just got done changing the oil, oil filters and fuel filters. It was doing this before I changed it all. Here are the numbers I am getting from my OBDII reader.
2 codes on OBDII
P0671 - Cylinder 1 Glow Plug Circuit Open
U0155 - Lost Communication with Instrument panel Cluster (IPC) Control
Module
The Instrument Cluster is currently out of the truck, I sent it off to a repair place to have it checked because it wasn't working, turns out that its not the cluster its something else.
DTCFRZRF P0155
Load PCT(%) 27.8
ETC(degrees F) 160
MAP(inHg) 31.9
RPM(/min) 703
VSS(mph) 27
IAT(degrees F) 77
MAF(lb/min) 5.020
Rum Tm(sec) 985
EGR PTC(%) 10.2
EGR ERR(%) 0.0
FLI(%) 0.0
Warmups 1
CLR Dist(mile) 0
Baro(inHg) 29.2
VPWR(V) 13.316
APP D(%) 20.0
APP E(%) 29.4
APP F(%) 18.4
Any info/advice on what to do/check next would be appreciated.
armybassanglers_james is offline
