2005 F350 battery light - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-02-2014, 07:20 AM Thread Starter
Howdy guys!
I've read through the list of battery light issues and none of them seem to be part of this problem.
I go out last week and turn on the truck to let the glow plugs warm up. The battery light is on solid. No other symptoms. The strange thing is that it stays lit until the engine hits operating temperature. Once it's at op temperature, the battery light goes off. It might blink every once in a while after that. Starts fine, to the battery voltage is 13.8. I've already got about $4000 into this fixing crap that has been broken or has quit.
It's a stock truck.
Thanks in advance!
sprat is offline
post #2 of 7 Old 08-02-2014, 07:36 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Well, there is only 3 parts to the charging system...
1) Alternator
2) Voltage Regulator
3) Batteries
Two of them are in the same unit, the alternator and voltage regulator.
My suggestion is to buy a battery charger and disconnect each battery and charge them independently.
If they don't charge or the light is still on, then it's the voltage regulator.
You'll need to replace it with a MotorCraft or specialty build like DC Power.
Do Not buy any other kind, especially auto parts store brands!!!!
Also remember that if your batteries are gone, you must replace them in pairs.
Good Luck.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
The Following User Says Thank You to dfuzz78 For This Useful Post:
sprat (08-02-2014)
post #3 of 7 Old 08-02-2014, 09:03 AM Thread Starter
Thanks, DFuzz78!
I just thought it odd it would go off at operating temp.
Since this is a single alt, should I be looking at the HD high amp alternator from Motorcraft?
sprat is offline
post #4 of 7 Old 08-02-2014, 09:09 AM
dfuzz78's Avatar
Your Welcome.
It wouldn't hurt...
Denis "Lt. Sled"
dfuzz78 is offline
post #5 of 7 Old 08-08-2014, 04:15 AM
Semiconductors like those used in voltage regulators have different characteristics based on their temperature. It would not be out of the question for it to behave differently when warm. On the alternator recommendations voiced above. I'm on my 4th alt in my '04. The original made it about 5 years. I replaced it with a Motorcraft from the dealer; it's a single alt. I think that one went about 3-4 years. Bought my next one at Autozone. It went less than one year. That may or may not be the alternators fault. It died after the truck was in the shop for an unrelated problem. When we got it back several fuses were blown and the alternator wouldn't charge. I think the shop shorted something while they were working on it. The shop was kind enough to install the free replacement from Autozone without admitting guilt. I spent much less on the Autozone alt and it was replaced for free with no questions asked when it failed. Like I said, I'm at least 50% sure the shop screwed it up. Even though it was free it would be a hassle if it needed to be swapped every year. We'll see how #4 works out.
tomshane is offline
post #6 of 7 Old 08-08-2014, 07:53 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Since your in Topton Pa. Your about 30 minutes away from PA Performance, they offer a 130amp and 200amp alternator with a lifetime warranty.
http://www.pa-performance.com/Script...eries%20Pickup
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 7 Old 08-08-2014, 07:56 PM
I got about 30k on a napa unit. No problems yet. Even if they are very easy to change.
KUGSS is offline
