Intermittent hot start long crank - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-01-2014, 06:39 AM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 41 Post(s)
Garage
This popped up once this past winter when I was in FL with the truck, and hasnt resurfaced since then till this past week.
After a long run on the highway (only happens after towing) of an hour or so is when it happens. Never happens around town, during the day or night, and never when not towing.
Its obviously an HPO leak. But curious on how to find out exactly where.
Last time it happened, we trailered my friends boat up the line to launch in RI to run offshore.
We left at 130am, ambient temps about 70*.
IAT was around 85*.
EOT and ECT were both hovering around 200*.
Stopped for fuel after about an hour on the road.
Truck was off for about 10-15min.
Try to start, cranked for about 2-3 seconds with no response.
I kept cranking and blipped the throttle- she fired up instantly.
I have done this in the past as well if it starts to crank longer than expected, I hold the throttle down a little, and she always fires immediately.
Happened again on the way back.
We stopped for iced coffee after about 1.5hrs.
Same deal, long crank, blip throttle, fires instantly.
My slightly educated guess is one of the dummy plugs or standpipes.
I replaced these when the motor had about 85k, I am at 113k now.
Injectors were new at 95k.
IPR valve and ICP sensor new at 100k.
Whats the best way to narrow down the drivers side or the passenger side for an oil leak?
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #2 of 3 Old 08-02-2014, 04:55 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 41 Post(s)
Garage
Anybody???
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #3 of 3 Old 08-02-2014, 05:42 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
You've gotta be able to supply air into the ICP port while energizing the IPR valve. Remove the oil fill cap and listen for air on passenger side, remove CCV hose and listen on drivers side and oil filter cap and listen also.
dhanna6powerstroke is offline
