EGR bracket - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-31-2014, 07:37 AM Thread Starter
EGR bracket
I have been looking around and could not find anything on this. My question is this, has anyone tried or heard of someone cutting the rear EGR bracket off after delete in order to be able to pull the intake without removing the turbo? I can't think of any reason why it would still be needed other than if you have to put the EGR back on down the road. I'm currently doing the oil cooler and it would be nice not to have to remove up-pipe from turbo as it is a huge PITA to get back on correctly.
Schooner622 is offline
post #2 of 6 Old 07-31-2014, 07:49 AM
I just did my oil cooler not too long ago. I thought about doing the same thing. I already had my egr cooler delete done and thought I could squeeze it outta there. I went ahead and took my turbo out. I figured why try to fix something if it ain't broke. I almost grabbed the sawsall and went after it. But then I thought what if I cut something else in the process. I opted for the turbo coming out
2006 F250 6.0 ltr
Egr cooler/Egr delete
3.5" stock down pipe with a no name 4" straight pipe, resonator and muffler deleted. Because let's face it, exhaust pipe is exhaust pipe no matter whose name is on it
SCT X4 Tuner -
Looney Tune by QuickTricks
Fuel Pressure Regulator Blue Spring Upgrade
PPE Oil Cooler
BD-Power Coolant Filtration
Zerex EC-1 Coolant
Delo 400LE 15w40
JohnnyJackMac is offline
post #3 of 6 Old 07-31-2014, 07:57 AM Thread Starter
Yea, a sawsall would probably lead to a mistake, but I'm thinking a hack saw would work and since it's aluminum wouldn't be hard or take long at all. Just not sure if that bracket provides some kind of rigidity or if it's something I should have done long ago and will be mad for not have done it sooner.
post #4 of 6 Old 07-31-2014, 08:23 AM
Just rigidity for the mounting of the egr cooler. That's all.
2006 F250 6.0 ltr
SCT X4 Tuner -
PPE Oil Cooler
Zerex EC-1 Coolant
Delo 400LE 15w40
post #5 of 6 Old 07-31-2014, 08:25 AM Thread Starter
Haha, well consider it cut the f off. Game on.
2006 F250 6.0 Lariat FX4
K&N air filter (for now)
Blue spring
Homemade straight pipe
Sinister intake anti-soot kit
New oil cooler and thermostat @ 160k
Rebuilt turbo @ 140k
Edge Insight CTS
"Those people don't know what it is to be a champion, Oklahoma invented it." -Barry Switzer
post #6 of 6 Old 07-31-2014, 08:53 AM Thread Starter
Just thought you might want to know it came off with very little effort. About 10 min of sawing by hand, intake came right out. I hit it with a grinder after to clean up the cut a bit.
Blue spring
Edge Insight CTS
