need help please - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-30-2014, 06:09 PM Thread Starter
need help please
I have a late 04 160000 miles on it. my oil cooler plugged up so I put a new cooler hpop stand pipes and dummy plugs and egr delete this was about a year ago. now my eot and ect was running high so I put another cooler in to make a long story short it was my radiator plugged after putting a new one my ect stays around 190 and eot pulling a little hill empty runs around 215 I have also put a new water pump front cover and electric fan does anyone have any ideas on what else could be the problem sorry for the long post any advice would be helpful thanks ps I did flush the system with vc9 before doing the new oil cooler and radiator
dj.oneil is offline
post #2 of 4 Old 07-31-2014, 05:46 AM
sonds's Avatar
You need to check eot and ect deltas on flat road at 65 mph. no hills or load on truck.
05 f-250 CC
4" MBRP turbo back kitty delete
EGR valve and cooler delete
Cat coolant
CAI
Edge Insight
Dieselsite coolant filter
Swamps 58v ficm
sonds is offline
post #3 of 4 Old 07-31-2014, 08:51 PM
Jeremy@NoLimit's Avatar
Quoted: 110 Post(s)
^^^^X's 2 on this. Also, have you flushed the coolant system properly? If not you are most likely going to plug up your oil cooler again.
Jeremy
2017 event info!!!!
-Jeremy- No Limit Fab
Sp@rtan, SCT, GH, PIP, H&S
Orders-1 800 581 8986
My direct line (706)549-5355
".org5" coupon code/discount for powerstroke.org members!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@NoLimit is offline
post #4 of 4 Old 07-31-2014, 09:37 PM Thread Starter
On flat ground it's between 5 &10 degrees different of each other ect stays around 187 and eot stays around 195 to 200 on the flat. I used 2 quarts of vc9 with each flush and got my ect up around 215 and drove it that way for about 2 hours and back flushed it each time before and after the vc9
dj.oneil is offline
