2003 idling at 2200 after motor work - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-30-2014, 05:03 PM Thread Starter
2003 idling at 1500 after motor work
My truck idles at 1500 rpms and wont slow down ... ideas?
I just replaced the following on truck, its a 2004, but manufacture date is 08/03 on the sticker.
blocked EGR cooler with plugs,
replaced oil cooler
replace HPOP orings (were split/leaking)
replaced all injector orings just as precaution
replaced radiator because of cracked overflow tube
flushed coolant 5 times prior to work and ran coolant filter for 300 miles
totalimpact is offline
post #2 of 3 Old 07-31-2014, 08:58 AM Thread Starter
from reading around I am going to take a wild stab that this is the ICP or harness???
But I have never heard of anyone having a sustained high idle because of this, almost everyone describes it as a poor or sporadic idle, or surging.... has anyone experienced it like mine?
post #3 of 3 Old 08-16-2014, 09:32 AM Thread Starter
So if anyone is hunting the same issue, I think it was the ICP... after pulling a bunch of junk out to get to it I sprayed down the sensor and harness real good and now its running great.
