Head gaskets or reman? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-29-2014, 03:31 PM Thread Starter
I have a 2004 6.0L with 150K miles, all stock. Hauling a horse across Wyoming, the truck started hesitating (and other bad behavior, white smoke, black smoke, coolant out the degass, etc)) in SD. I stopped in Rapid City to have it checked by two different shops telling me the same thing - head gaskets. We drove it home dumping 12 gallons of 50/50 over the course of 1200 miles. The shop at home says the same thing, but I think they are going to recommend a reman engine.
I have no doubt about the head gaskets b/c the thing smells sweet and smokes like a locomotive. If the heads are cracked and I need to replace those anyway, what is the downside (other than dollars) of a reman engine at this stage for this truck?
Do you have any recommendations for reman suppliers? Am I foolish for considering a reman over repairing what I have?
Happy to answer any questions - thanks in advance.
RubyHauler is offline
post #2 of 4 Old 07-29-2014, 04:29 PM
Just me but if I had the cash I would just throw a reman in it making sure it is studded and get rid of the egr cooler or the bpd one, then call it a day for hopefully a long time. I cant recommend a reman but there was one that looked good but I cant recall the name. I think it was about 8K before shipping. More depending on upgrades.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
post #3 of 4 Old 07-29-2014, 04:39 PM
Mexfdmnb's Avatar
If you are gonna go the reman route try giving ashvilleengines.com a call they may be able to help you out in that department.
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #4 of 4 Old 07-30-2014, 02:54 PM Thread Starter
The shop is a Jasper dealer, so they'd be putting in either a long-block or running complete reman. I'm leaning toward the running complete b/c of the age of my truck plus any other damage to the top end of things during my run back east with bad gaskets.
Tags
6.0 , heads , reman
