Stuck at a campground and can't get running - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-28-2014, 01:55 PM Thread Starter
casper4203's Avatar
I went camping and my truck died.
Pulled the trip just fine. Went out to the store and lost all my ICP pressure like a light went out. My ICP stays right at 45-50 psi. My ICP voltage is at .3
I replaced the IPR with a spare that I had. No change. So with it being so little pressure, I felt sure it was the HPOP. I had just enough tools to replace the HPOP. But not to do an air test. Replaced the HPOP an no change.
Anyone have any suggestions?
Not my best vacation. And I'm against the wall in OC, MD
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 7 Old 07-28-2014, 02:03 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
Stc fitting(if 05 or later) or bad icp?
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #3 of 7 Old 07-28-2014, 03:25 PM
crash&burn's Avatar
What Is the brand of HPOP you put in.
What is the IPR reading.
If the ICP is bad you should be able to unplug it and if it is the ICP the truck should start with it unplugged.
what year is your truck.
Do you have a low oil pressure reading
What oil are you using.
When was the last oil change.
What oil filter are you using.
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #4 of 7 Old 07-29-2014, 03:28 AM Thread Starter
casper4203's Avatar
The IPR was at .3
I unplugged the ICP when I first broke down and it didn't change
My truck is a 2005
My oil pressure is at 50 psi
I changed the oil just last weekend using Rotella synthetic and a Motorcraft filter
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #5 of 7 Old 07-29-2014, 04:27 AM
crash&burn's Avatar
Originally Posted by casper4203 View Post
The IPR was at .3
My truck is a 2005
Did you change the SCT fitting when you installed the HPOP
Shawn
post #6 of 7 Old 08-03-2014, 02:18 PM Thread Starter
casper4203's Avatar
Well it was a top o-ring. Looks like the retainer clip gave up and the spacer ring split in half. Everything was wrapped around the nipple cup when I pulled the rail off
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #7 of 7 Old 08-03-2014, 02:39 PM
ZMANN's Avatar
Quoted: 1584 Post(s)
glad you got it
I was feeling bad for you doing an HPOP for no reason
We Miss you Ronnie
ZMANN is offline
