Rollin Coal...ole smoky - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-27-2014, 06:59 PM Thread Starter
So now that I have the diesel in my oil issue resolved I now have an excessive smoking issue when the truck is cold or sits for 4 or more hours. Once started you can hear a fuel knock and the injectors clattering and she has a slightly ruff idle. I'm thinking a few injectors may be stuck, possibly from sitting so long.Its a nice heavy cloud of white smoke, very fuel smelling. It will smoke as long as it sits there. Once you pull it out on the road and accelerate up to speed its gone for the rest of your drive. I'm figuring the hpo is putting enough pressure into the injectors to free them up. I've also just started running this hotshot oil additive that claims to free up injectors. Keeping my fingers crossed. Has anyone had any luck with this product? Any suggestions to the smoking issue? Thanks.
jamiesoncd is offline
post #2 of 13 Old 07-27-2014, 07:19 PM
Are you really sure it is smoke and not largely steam? The steam part will dissipate faster than the smoke. Is it using ANY coolant yet?
sjsche is offline
post #3 of 13 Old 07-27-2014, 07:47 PM
Try archoil 9100 or rev x if it is stiction. Be prepared to replace the injectos sooner later see if it cures it or take it in to due a power contrubution test.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #4 of 13 Old 07-28-2014, 05:04 AM Thread Starter
Not steam. Its not using any coolant. It'll burn your eyes out with fumes in the garage. Injectors were done a little over a year ago. Just replaced #7 a month ago and did all the injector orings due to fuel leaking into the oil.
post #5 of 13 Old 07-29-2014, 02:37 AM Thread Starter
Also how does the oil circulate in the injector oil gallies? It seems like a closed loop on top of the injectors. It looked like to me the oil came in the back fill tube with a check valve bit had no way out. How does any kind d of sticktion fluid get up in there if the y r already full of oil?
post #6 of 13 Old 07-29-2014, 02:39 AM Thread Starter
BTW that pic is of a cold start up this morning. About 70 out. Went away just before I hit 55mph . so within 30 sec of driving. Not even a puff after that all the way to the job site.
post #7 of 13 Old 07-30-2014, 05:07 AM Thread Starter
I also pulled a code this morning P0069...map-baro correlation
post #8 of 13 Old 08-29-2014, 12:55 PM Thread Starter
I had my buddy stop by with his scanner and check everything over. IPR,IPC, ficm voltage, codes etc...everything in spec. Performed an injector test and found that 5 inj were shot, stiction most likely. So I tucked tail and went down to ford and bought all new injectors. After install and start up she ran smooth and drove great. No more skipping when cold. BUT she still smokes like a pig till ya drive her a half a mile. I'm just about tapped out after buying injectors. What else could it be. Turbo seals? Saw a bunch of vids on YouTube with the same problem and they were saying that turbo seals or injectors fixed the problem. Any help would be great. I'm lost and extremely frustrated.
post #9 of 13 Old 08-29-2014, 01:05 PM
Teachagmech's Avatar
Quoted: 399 Post(s)
Garage
If it's only on startup after sitting it seems like it's just leaking into the cylinders. It could be a cracked head at the injector cup. Once the heads warm up the Crack could swell shut enough to slow the flow of fuel into the cylinder(s).
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #10 of 13 Old 08-30-2014, 05:17 AM Thread Starter
The thing is is it can side there and idle and smoke at operating temp. As soon as I drive it it goes away weather its a cold or hot engine. I did notice a small amount of play in the turbo charge side shaft. As of now I'm not using any coolant, no codes and the exhaust burnts your eyes with fuel . can I unplug injectors one at a time with it running to see if the smoke quits and narrow it down to a specific cylinder?
