C. Temp. wont come up above 170 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-26-2014, 06:23 PM Thread Starter
Well kinda,
Just got the truck, when test driving it the temp was doing the same thing, so when I bought it, the first thing I did was change the thermostat (OEM Motorcraft) and it seemed to come up to around 190 or so, good.
So today with ambient temps around 90, it showed good at 195 and then when i got on the highway, running ~70 it started to drop then reached 170 and didnt budge, even when i got off the highway it didnt go up, or down or anything.
Im leaning toward the coolant temp. sensor, i guess the thermostat could be bad, maybe I got a dud. The main reason im leaning to the temp. coolant sensor is it seems to get to 170 and just stop, no fluctuation.
Where is the sensor located?
zgzmithr is offline
post #2 of 5 Old 07-26-2014, 06:32 PM
What are you using to read temp?
If you can, connect a ScanGauge II or similar that will display both coolant and engine oil temps. Now you know exactly what the ECU thinks it is, and if the oil temp is similarly low then they are likely accurate, if not then may be the sender.
sjsche is offline
post #3 of 5 Old 07-26-2014, 06:35 PM Thread Starter
Im using a Creader, Oil Temp. was about 199 to 205 at the max. Even at first when the coolant temp. was reading normal today
zgzmithr is offline
post #4 of 5 Old 07-26-2014, 08:15 PM
But is oil temp up around 200 when coolant suspiciously reads 170? If so, and it doesn't eventually follow the coolant temp down, then I would guess your new t-stat is fine and the sender is faulty. Does the stock dash gauge read normal or a bit low?
sjsche is offline
post #5 of 5 Old 07-26-2014, 11:26 PM Thread Starter
it does not follow it down sjsches.
the oil temp holds as the coolant temp dropped. I came to the conclusion it was the sender so i ordered a new motorcraft one. Im sure it wont be here though before i leave for 10 days, so ill update when i get home.
dont worry, im not driving the truck neways.
zgzmithr is offline
