6.0 will not start when hot...sometimes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-26-2014, 12:09 PM Thread Starter
2005 6.0 will not start when hot.. sometimes. If it cools down for 1 hr or so it's ok. 2 different shops said it was the oil sensors in the heads, 2 in each, $1000 to if I am lucky, every time I took it to a shop it would run fine, no problems 6 times at one shop.I have a Cam OBD2 when I test it I get "turbo/super charger under boost" PO 299 generic. then the yellow light comes on under emission status. I cleaned the batteries, new this yr, and changed the fuel filters, so far so good. but what is PO 299???
One more thing when it did start for a few min. there was no throttle response, the engine would only idyll. I do not have any tools to test things with, except a volt-amp gauge. Thanks for any help.
Lou B is offline
post #2 of 7 Old 07-26-2014, 12:30 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
Try unplugging the ICP sensor and see if it will start.
Either way, you more than likely have a HPO leak. Could be the HPOP, STC fitting, standpipes, dummy plugs, IPR valve, any of the mentioned or a combination of them.
If you have the time, general knowledge, and ability to turn wrenches you can tackle it on your own instead of having a shop rape your wallet to do it.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 7 Old 07-26-2014, 12:41 PM Thread Starter
Thanks Rattlesnake18 I tried that one time burned the hell out of my arm. Like I said I cleaned the batteries, had blue stuff on them, and I changed fuel filters, 12000 miles. So far no problems. Still looking to what PO 299 generic code means?
Lou B is offline
post #4 of 7 Old 07-26-2014, 12:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
google it. 99.9% of the time it will come right up. Also try it in the search function up above. And if you look around somewhere on here is the 6.0 bible. Great info to download. I copied it off at work. And it has a section that has all the codes as well.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 7 Old 07-26-2014, 12:47 PM
RIP Cam!
P0299 is the turbo over boost/under boost code.
Could be a dirty sensor or sticking veins in your turbo. I would check the EBP sensor first and clean the tube as well to start with concerning that code.
The Following User Says Thank You to Rattlesnake18 For This Useful Post:
Lou B (07-26-2014)
post #6 of 7 Old 07-26-2014, 08:40 PM Thread Starter
Ok where is the EBP? and how do I clean the tube? At least once a week on the freeway I put my foot in it, look at the turbo boost gauge watch it go to 20 or 24 for a min. and back off, is that enough to get the vanes in the turbo moving? truck runs really good at high rpm,
Lou B is offline
post #7 of 7 Old 07-27-2014, 07:21 AM
RIP Cam!
Here is a good thread to read.... 06 F250- EBP Cleaning
By the way, when putting the sensor back on, do not tighten it too tight or you will snap it off and have to buy a $130+ sensor, ask me how I know.
