FICM wiring? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-26-2014, 11:19 AM Thread Starter
RoCkfiSh363's Avatar
FICM wiring?
Hey guys, I screwed up my FICM pigtail connector (32 pin closest to front of truck) So I took all the wires out of the plastic plug and put them into a new connector shell. There's 5 black and pink and 4 Green and light green wires. I didn't mark them cause I figured they are grounds and powers and wouldn't matter if I had them mixed up. Am I dead wrong?? I put the new ficm in and plugged it all back together and now it cranks but won't start. Were those grounds and powers specific to each pin??? Please any info is greatly appreciated.
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 3 Old 07-27-2014, 01:34 PM
1NastySS's Avatar
Quoted: 9 Post(s)
I feel your pain,I replaced 2 of mine and what a BIT**.Luckily Ive got the wiring manual.Did you make sure to put the ground wire back on the manifold if you removed it?
1NastySS is offline
post #3 of 3 Old 07-27-2014, 04:35 PM Thread Starter
I don't think I removed it but I will check. I talked with a Diesel tech and he said that all the grounds ( blk/pnk) and all the switched powers ( Grn/light green) all go to the same place in the harness so not to worry about that. I'm guessing I didn't get the connector piece together right or something. Such a tedious hassle
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
