Blue smoke at takeoff from stop 04 6.0 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-24-2014, 12:12 PM Thread Starter
2004 ccsb studded deleted stock turbo stock injectors magnaflow exhaust:
Have a issue with bluish smoke coming from exhaust when taking off from stop. Can also make it happen when truck is in gear and you bring it up on boost for about 5 sec and it goes away. Same from stoplight it smokes for a sec and goes away. Full throttle nothing no smoke any other time. Only at take off or first part of throttle. Let it sit for 20 sec and repeat and it does same thing.
Things I have changed:
Swapped Turbos from another on shelf known good or should have been...
IPR oring had small tear in it so replaced
IPR swapped with another known good one
previously owner installed 8 brand new alliant injectors approx 400 miles ago
Truck runs fantastic starts easy and no smoke at startup. No haze no nothing. After turbo swap it seemed to go away and drove it 100 miles and about 3 days later I drove it again and noticed it happening again. It may have not went away or I just didnt notice it???? Im a dealer and I bought truck right after the alliants were put in. Have to make this truck right I dont want to sell anything I know is broke or has issues.
Anyone have ideas?
Have also had on AE and no codes balance tests good KOEO Good KOER Good Nothing showed. FICM Volts 48.5 All Good...
MidwestDieselTrucks.net is offline
post #2 of 5 Old 07-24-2014, 01:25 PM
peixinho's Avatar
Quoted: 174 Post(s)
Are you running stock tuning? It could be a tuning issue.
Have you changed your oil recently? I have seen really dirty oil cause issues
What oil r u running? Try switching to synthetic
U could have potential had 2 bad turbos (but that is unlikely)
I have had a couple of guys have this problem on newer upgraded turbos... and they all turned out to not be the turbo... but it was coming through the turbo. A clogged CCV can cause cylinder blow by to go through the turbo. Also if you have diesel in your oil then it can dilute the oil enough that it can blow right through your seals on the turbo.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
The Following User Says Thank You to peixinho For This Useful Post:
MidwestDieselTrucks.net (07-24-2014)
post #3 of 5 Old 07-24-2014, 02:01 PM Thread Starter
yes stock tuning, oil is good and was changed at injector replacement, no diesel signs in oil, will check ccv, I hope not 2 bad turbos... I have 1 more on shelf I can try tho if I have to. Thanks... Will update once I do more.
post #4 of 5 Old 07-24-2014, 04:55 PM Thread Starter
ok checked ccv and thats no issue. Motor has nearly zero blow by at full operating temp... Now what? Any ideas?
post #5 of 5 Old 07-25-2014, 11:06 AM Thread Starter
only will do it when at full operating temp. tried to make it do it cold today and wouldnt...
